ExoHyde Pro Grade Textured Protective Speaker Cabinet Coating Gallon - BlackExoHyde Protective Coating is an easy to apply low VOC paint that provides superior adhesion to most surfaces and dries to a hard, resilient finish for a durable and weather resistant coating. ExoHyde's thick constancy and fast drying time makes it easy to create a variety of textures with a very attractive finish. Thanks to the superior adhesion properties, no primer coat is necessary making the application a simple one step process. Originally designed as a professional finish for speaker enclosures, this paint can be used in a variety of situations.
Application of Exohyde is extremely easy. For surface preparation, just fill any pits and voids with putty or wood filler, sand all surfaces smooth, and remove any dust. Then, apply a heavy coat of ExoHyde to achieve the texture you want. The recommended foamPRO foam texture rollers will create a consistent texture with the look and durability of an expensive professional finish. One coat is usually all that is needed for complete coverage. However, you can use multiple coats to increase the overall texture, durability, and water resistance.
Since ExoHyde is water soluble when wet, cleanup is as easy as can be. Simply rinse brushes or rollers with water after application and they can be reused many times. Once dry, ExoHyde is extremely water resistant and very difficult to remove which allows you to clean any dirty finished surfaces with soap and water.
One gallon of Exohyde can cover an area of 100 to 120 square feet in a single coat.
Notes: • Stir Exohyde thoroughly before use and occasionally during prolonged usage to prevent pigment from settling to the bottom of the can.
• Application over primer is not recommended, Exohyde is a self priming paint and is not compatible with certain primers. If you plan on using a separate primer then apply on a sample piece first to ensure compatibility.
ExoHyde pro grade textured protective speaker cabinet coating is also available in a quart size for smaller projects.
