  • Tang Band W8-740P 8" Subwoofer
Tang Band
Part #264-854
Tang Band
Part #264-854
Model: W8-740P
The W8-740P is one of the highest excursion 8" subwoofers available on the market. It utilizes a heavy-duty paper cone, foam surround, and bumped back plate for maximum mechanical movement.
  • One of the highest excursion 8" subwoofers available on the market
  • Heavy-duty paper cone
  • Bumped back plate for maximum mechanical movement
  • This item available through special order only. Minimum order quantity is 50 pieces
Your Price: $134.98
MSRP: $224.99
Save $90.01 (40%)
Quantity:Qty: 50+$134.98/ea
Out of Stock
Ships in 90-120 days, minimum order quantity 50 pcs.
Alert Me When Available
The W8-740P is one of the highest excursion 8" subwoofers available on the market. It utilizes a heavy-duty paper cone, foam surround, and bumped back plate for maximum mechanical movement. The 2" 4-layer voice coil, vented pole piece, and heavy-duty aluminum voice coil former provide impressive power handling. Excellent for small-enclosure home or automotive subwoofers.
BrandTang Band
ModelW8-740P
Part Number264-854
UPC844632009822
Weight10.5201
Nominal Diameter8"
Bolt Circle Diameter7.83
Power Handling (RMS)120 Watts
Power Handling (MAX)240 Watts
Frequency Response30 to 1,000Hz
Sensitivity84dB 2.83V/1m
Voice Coil Diameter2"
Resonant Frequency (Fs)30Hz
DC Resistance (Re)3.2Ω
Voice Coil Inductance (Le)0.84mH
Mechanical Q (Qms)3.69
Electromagnetic Q (Qes)0.31
Total Q (Qts)0.28
Compliance Equivalent Volume (Vas)0.71ft³
Mechanical Compliance of Suspension (Cms)0.29mm/N
BL Product (BL)13.66T·m
Diaphragm Mass Inc. Airload (Mms)94.26g
Maximum Linear Excursion (Xmax)12.1mm
Surface Area of Cone (Sd)220cm²
Cone MaterialPaper
Surround MaterialFoam
Voice Coil FormerAluminum
Overall Outside Diameter8.27"
Baffle Cutout Diameter7.25"
Depth4.75"
Vented Volume0.63ft³
Vented F327.8Hz
