  • Dayton Audio RS180S-8 7" Reference Shielded Woofer 8 Ohm
Dayton Audio
Part #295-364
Dayton Audio
Part #295-364
Model: RS180S-8
The Dayton Audio Reference Series sets a new standard of value in high-performance loudspeaker drivers. Utilizing a low-distortion motor system with two short-circuit paths and a rigid aluminum cone, the Reference Series can outperform drivers that cost several times the price.
  • Long-excursion motor and suspension for strong bass performance
  • Subtle yet high-tech look makes a bold cosmetic statement
  • Ultra-low stray magnetic field allows extremely close proximity to CRT's
  • Designed and engineered in the USA
Your Price: $74.98
MSRP: $94.99
Save $20.01 (21%)
Quantity:Qty: 1-3 $74.98/ea
Quantity:Qty: 4+$67.48/ea
Order in the next 4 hr 39 min to ship today. Details
The Dayton Audio Reference Series sets a new standard of value in high-performance loudspeaker drivers. Utilizing a low-distortion motor system with two short-circuit paths and a rigid aluminum cone, the Reference Series can outperform drivers that cost several times the price. Their low-distortion characteristics and high excursion capabilities provide exceptional clarity, detail, and dynamics. Woofers feature a shielded motor system, black anodized cone, heavy-duty 6-hole cast frame, low-loss rubber surround, and solid aluminum phase plug.
ModelRS180S-8
Part Number295-364
UPC844632000331
Weight5.5
Nominal Diameter7"
Bolt Circle Diameter6.63
Power Handling (RMS)60 Watts
Power Handling (MAX)120 Watts
Frequency Response41 to 3,600Hz
Sensitivity86.9dB 2.83V/1m
Voice Coil Diameter1"
Resonant Frequency (Fs)37.7Hz
DC Resistance (Re)6.4Ω
Voice Coil Inductance (Le)0.79mH
Mechanical Q (Qms)1.45
Electromagnetic Q (Qes)0.49
Total Q (Qts)0.36
Compliance Equivalent Volume (Vas)0.812ft³
Mechanical Compliance of Suspension (Cms)1.05mm/N
BL Product (BL)7.28T·m
Diaphragm Mass Inc. Airload (Mms)17g
Surface Area of Cone (Sd)124.7cm²
Cone MaterialAluminum
Voice Coil FormerAluminum
Overall Outside Diameter7.11"
Baffle Cutout Diameter5.75"
Depth3.86"
# Mounting Holes6
Sealed Volume0.17ft³
Sealed F396Hz
Vented Volume0.48ft³
Vented F348Hz
