  • Dayton Audio RS52AN-8 2" Reference Aluminum Dome Midrange
Dayton Audio
Part #285-020
Dayton Audio
Part #285-020
Model: RS52AN-8
The Dayton Audio Reference Series dome midrange delivers excellent off-axis response and midrange performance. High quality construction includes a cast aluminum faceplate, metal grill, vented former, and copper clad pole piece.
  • Large damped rear chamber for low resonance point
  • 2" Aluminum diaphragm for good clarity and dispersion
  • Neodymium magnet minimizes stray magnetic field
  • Copper clad motor reduces distortion for transparent sound
Your Price: $45.49
MSRP: $58.99
Save $13.50 (23%)
Quantity:Qty: 1-3 $45.49/ea
Quantity:Qty: 4+$40.94/ea
Order in the next 2 hr 50 min to ship today. Details
Only 8 In Stock
More due any day
The Dayton Audio Reference Series dome midrange delivers excellent off-axis response and midrange performance. Its black anodized 2" diaphragm is extremely linear throughout the midrange and lower treble, allowing it to provide a seamless transition to tweeters. The superior dispersion characteristics will eliminate suckouts and other problems that can occur in typical two-way designs with large woofers. High quality construction includes a cast aluminum faceplate, metal grill, vented former, and copper clad pole piece. Great for use with other members of the Reference Series, but will also work well with any high-performance driver.
ModelRS52AN-8
Part Number285-020
UPC844632067716
Weight1.0001
Nominal Diameter2"
Power Handling (RMS)60 Watts
Power Handling (MAX)120 Watts
Frequency Response500 to 14,000Hz
Sensitivity89.4dB 2.83V/1m
Voice Coil Diameter2"
Resonant Frequency (Fs)341Hz
DC Resistance (Re)
Voice Coil Inductance (Le)0.13mH
Mechanical Q (Qms)3.16
Electromagnetic Q (Qes)1.18
Total Q (Qts)0.86
Compliance Equivalent Volume (Vas)0.005ft³
BL Product (BL)4.26T·m
Surface Area of Cone (Sd)26.4cm²
Cone MaterialAluminum
Voice Coil FormerAluminum
Magnet MaterialNeodymium
Overall Outside Diameter5.12"
Baffle Cutout Diameter3.94"
Depth2.24"
# Mounting Holes6
