  • Tang Band W5-2143 5" Paper Cone Full Range Driver 8 Ohm
Tang Band
Part #264-958
Tang Band
Part #264-958
Model: W5-2143
With a bamboo fiber paper cone, structured Santoprene surround, and underhung motor, the W5-2143 5" full range from Tang Band has impressive response from 55 to 20,000 with very low distortion.
  • Aluminum phase plug also acts as a shorting ring for lower distortion
  • Underhung voice coil improves control for lower distortion
  • Impressive efficiency (90 dB 1W/1m) for a driver this small
  • Unique surround and large spider keeps cone linear well beyond the rated xmax
Your Price: $100.89
MSRP: $151.99
Save $51.10 (34%)
Quantity:Qty: 1-3 $100.89/ea
Quantity:Qty: 4-9 $95.85/ea
Quantity:Qty: 10+$92.82/ea
71In Stock
Tang Band's versatile W5-2143 full range driver uses an underhung voice coil, which places the entire coil inside the magnetic gap, for the utmost in control and accuracy. Designed for minimum distortion and resonance, the bamboo fiber paper cone and structured surround produces smooth response without harsh peaks or dips. The aluminum phase plug improves off axis response while also acting as a shorting ring providing greater control of the voice coil resulting in lower distortion.
BrandTang Band
ModelW5-2143
Part Number264-958
UPC848864023779
Weight4
Nominal Diameter5"
Bolt Circle Diameter5.7
Power Handling (RMS)30 Watts
Power Handling (MAX)60 Watts
Frequency Response55 to 20,000Hz
Sensitivity90dB 2.83V/1m
Voice Coil Diameter1"
Resonant Frequency (Fs)55Hz
DC Resistance (Re)6.3Ω
Mechanical Q (Qms)3.21
Electromagnetic Q (Qes)0.43
Total Q (Qts)0.38
Compliance Equivalent Volume (Vas)0.67ft³
Mechanical Compliance of Suspension (Cms)1.4mm/N
BL Product (BL)5.43T·m
Diaphragm Mass Inc. Airload (Mms)5.99g
Surface Area of Cone (Sd)97.83cm²
Cone MaterialBamboo Fiber / Paper
Surround MaterialSantoprene®
Overall Outside Diameter6.125"
Baffle Cutout Diameter4.84"
Depth3.34"
Sealed Volume0.3ft³
Sealed F3115.2Hz
Vented Volume0.5ft³
Vented F361.3Hz
