Tang Band W4-2142 4" Paper Cone Full Range Driver 8 Ohm
- Underhung voice coil improves control for lower distortion
- Aluminum phase plug also acts as a shorting ring for lower distortion
- Impressive efficiency (88 dB 1W/1m) for a driver this small
- Unique surround and large spider keeps cone linear well beyond the rated xmax
- This item available through special order only. Minimum order quantity is 50 pieces
Out of Stock
We'll send you an email when Tang Band W4-2142 4" Paper Cone Full Range Driver 8 Ohm is back in stock or available for preorder.
