  • Tang Band W3-2141 3" Paper Cone Full Range Driver 8 Ohm
Tang Band
Part #264-956
Tang Band
Part #264-956
Model: W3-2141
With a bamboo fiber paper cone, structured Santoprene surround, and underhung motor, the W3-2141 3" full range from Tang Band has impressive response from 75 to 20,000 with very low distortion.
  • Aluminum phase plug also acts as a shorting ring for lower distortion
  • Underhung voice coil improves control for lower distortion
  • Impressive efficiency (87 dB 1W/1m) for a driver this small
  • Unique surround and large spider keeps cone linear well beyond the rated xmax
Your Price: $59.98
MSRP: $67.99
Save $8.01 (12%)
Quantity:Qty: 1-3 $59.98/ea
Quantity:Qty: 4+$56.98/ea
20In Stock
Tang Band's versatile W3-2141 full range driver uses an underhung voice coil, which places the entire coil inside the magnetic gap, for the utmost in control and accuracy. Designed for minimum distortion and resonance, the bamboo fiber paper cone and structured surround produces smooth response without harsh peaks or dips. The aluminum phase plug improves off axis response while also acting as a shorting ring providing greater control of the voice coil resulting in lower distortion.
BrandTang Band
ModelW3-2141
Part Number264-956
UPC848864023762
Weight1.6
Nominal Diameter3"
Bolt Circle Diameter3.375
Power Handling (RMS)25 Watts
Power Handling (MAX)50 Watts
Frequency Response75 to 20,000Hz
Sensitivity87dB 2.83V/1m
Voice Coil Diameter0.8"
Resonant Frequency (Fs)75Hz
DC Resistance (Re)6.5Ω
Mechanical Q (Qms)2.51
Electromagnetic Q (Qes)0.46
Total Q (Qts)0.39
Compliance Equivalent Volume (Vas)0.116ft³
Mechanical Compliance of Suspension (Cms)2.25mm/N
BL Product (BL)3.64T·m
Diaphragm Mass Inc. Airload (Mms)1.669g
Maximum Linear Excursion (Xmax)1.6mm
Surface Area of Cone (Sd)32.09cm²
Cone MaterialBamboo Fiber / Paper
Surround MaterialSantoprene®
Overall Outside Diameter3.625"
Baffle Cutout Diameter2.92"
Depth2.25"
Sealed Volume0.05ft³
Sealed F3152.4Hz
Vented Volume0.09ft³
Vented F382.5Hz
