  • Tang Band W4-1720 4" Underhung Midbass Driver
Tang Band
Part #264-872
Tang Band
Part #264-872
Model: W4-1720
The W4-1720 4" midbass features a long throw, underhung 1-1/4" voice coil driven by a massive ferrite magnet structure.
Your Price: $92.98
MSRP: $101.99
Save $9.01 (9%)
Estimated back in stock 5/30/2025
Alert Me When Available
A shorting ring on the polepiece is responsible for the speaker's extremely low levels of second and third order harmonic distortion. This impressive motor is coupled to an optimized paper cone with rubber surround, supported by a cast aluminum frame.
BrandTang Band
ModelW4-1720
Part Number264-872
UPC844632069604
Weight4.1
Nominal Diameter4"
Power Handling (RMS)30 Watts
Power Handling (MAX)60 Watts
Frequency Response60 to 8,000Hz
Sensitivity86dB 2.83V/1m
Voice Coil Diameter1.25"
Resonant Frequency (Fs)60Hz
DC Resistance (Re)3.8Ω
Voice Coil Inductance (Le)0.04mH
Mechanical Q (Qms)2.33
Electromagnetic Q (Qes)0.51
Total Q (Qts)0.42
Compliance Equivalent Volume (Vas)0.21ft³
BL Product (BL)3.82T·m
Diaphragm Mass Inc. Airload (Mms)5g
Surface Area of Cone (Sd)57cm²
Cone MaterialPaper
Overall Outside Diameter4.95"
Baffle Cutout Diameter3.75"
Depth3.25"
Sealed Volume0.15ft³
Sealed F3114.6Hz
Vented Volume0.2ft³
Vented F359.7Hz
