  • Parts Express Speaker Gasketing Tape 1/8" x 1/2" x 50 ft. Roll
Part #260-542
Part #260-542
Finally! A foam gasketing tape designed specifically for loudspeakers! This specially designed foam tape is excellent for making an airtight seal around drivers, terminals, handles, horn lenses, or any other item that needs installed in your cabinet!
  • Adhesive backed for easy installation
  • Ensures a good seal to enclosures
  • Perfect for drivers, handles, horns, or anything that needs to be air-tight
Your Price: $13.98
MSRP: $14.99
Save $1.01 (7%)
Quantity:Qty: 1-3 $13.98/ea
Quantity:Qty: 4+$12.58/ea
Finally! A foam gasketing tape designed specifically for loudspeakers! This specially designed foam tape is excellent for making an airtight seal around drivers, terminals, handles, horn lenses, or any other item that needs installed in your cabinet! The closed cell PVC foam is a dark charcoal color that eliminates unsightly bright-colored seams, while the high-tack adhesive aggressively sticks to all speaker frames-- unlike the "gray stuff" from your hardware store. The 3/8" width can be used on drivers as small as 3"; use the 1/2" width for larger 10's, 12's, 15's, and 18's. 1/8" thick, sold in 50 ft. rolls.
Part Number260-542
UPC844632043000
Unit of MeasureRolls
Weight0.55
MONSTER DEAL
OF THE WEEK
$98.98 EACH
SAVE 40%
Dayton Audio DTA-PRO 100W Class D Bluetooth Amplifier with USB DAC IR Remote and Sub Output
