  • Peerless by Tymphany NE149W-08 5-1/4" Fiber Cone Woofer Speaker 8 Ohm
NEW Peerless by Tymphany NE149W-08 5-1/4" Fiber Cone Woofer Speaker 8 Ohm
Part #264-1132
Model: NE149W-08
The advanced design and superior construction of Tymphany's NE149W-08 5-1/4" neodymium speaker make it a preferred component for sophisticated audio designs.
  • Sculpted design improves airflow and reduces reflections
  • High-strength compact neodymium magnet system
  • Proprietary coated natural wood fiber cone with half-roll rubber surround
  • Copper pole piece cap for extended HF response
  • Long-throw 1-1/2" voice coil on titanium former
  • Cast aluminum frame promotes motor cooling
  • 8 ohm nominal impedance
NEW $76.37
MSRP: $103.99
Save $27.62 (27%)
Ships in 90-120 days, minimum order quantity 300 pcs.
Alert Me When Available
The Tymphany NE149W-08 5-1/4" neodymium woofer is characterized by the NE Series' cast aluminum basket—an innovative sculpted, open design that minimizes internal acoustic reflections and assists the neodymium motor's thermal management.
A coated natural wood fiber cone with a butyl rubber surround is FEA optimized for linearity of performance. Finite element analysis techniques also contribute to inclusion of the motor's copper cap, which reduces inductance and extends the speaker's upper frequency performance.
BrandPeerless by Tymphany
ModelNE149W-08
Part Number264-1132
UPC844632092602
Weight1.55
Nominal Diameter5-1/4"
Power Handling (RMS)60 Watts
Power Handling (MAX)120 Watts
Frequency Response50 to 5,000Hz
Sensitivity86dB 2.83V/1m
Voice Coil Diameter1.5"
Resonant Frequency (Fs)54Hz
DC Resistance (Re)6.3Ω
Voice Coil Inductance (Le)0.08mH
Mechanical Q (Qms)8.19
Electromagnetic Q (Qes)0.4
Total Q (Qts)0.38
Compliance Equivalent Volume (Vas)0.3ft³
Mechanical Compliance of Suspension (Cms)0.84mm/N
BL Product (BL)7.42T·m
Diaphragm Mass Inc. Airload (Mms)10.3g
Surface Area of Cone (Sd)85cm²
Cone MaterialWood Fiber
Voice Coil FormerTitanium
Magnet MaterialNeodymium
Overall Outside Diameter5.39"
Baffle Cutout Diameter4.92"
Depth3.18"
# Mounting Holes5
Sealed Volume0.15ft³
Sealed F3113.8Hz
Vented Volume0.35ft³
Vented F351.6Hz
MONSTER DEAL
OF THE WEEK
$98.98 EACH
SAVE 40%
Dayton Audio DTA-PRO 100W Class D Bluetooth Amplifier with USB DAC IR Remote and Sub Output
