  • Peerless by Tymphany 830860 5-1/4" PPB Cone HDS Woofer
NEW Peerless by Tymphany 830860 5-1/4" PPB Cone HDS Woofer
Part #264-1080
Model: HDS-P830860
The Peerless High Definition Sound (HDS) Series offers high-quality solutions for multi-way speaker systems employing vented box alignments.
  • Truncated cast aluminum frame
  • PPB polypropylene cone with half-roll rubber surround
  • Long-throw voice coil
  • Shorting rings for reduced distortion
  • Under-spider and voice coil ventilation
NEW $33.56
MSRP: $57.99
Save $24.43 (42%)
Quantity:Qty: 500+$33.56/ea
Ships in 90-120 days, minimum order quantity 500 pcs.
Alert Me When Available
The Peerless High Definition Sound (HDS) Series offers high-quality solutions for multi-way speaker systems employing vented box alignments. A powerful ferrite magnet system is coupled to a finite element analysis-designed suspension system, containing a linear spider design and rubber surround. The motor incorporates an aluminum shorting ring that reduces coil inductance, extending frequency response performance and reducing second harmonic distortion. A cast aluminum basket provides high structural rigidity, heat-sinking capacity for the motor, and additional ventilation under the spider that in combination with a vented cone neck reduces air compression effects. Peerless developed the proprietary and highly advanced Polypropylene Black (PPB) cone material used in the HDS PPB Series, creating a stiff but still dampened cone that remains stable even under the greatest sound pressures.
BrandPeerless by Tymphany
ModelHDS-P830860
Part Number264-1080
UPC844632084010
Weight2.5
Nominal Diameter5-1/4"
Power Handling (RMS)30 Watts
Power Handling (MAX)60 Watts
Frequency Response60 to 5,000Hz
Sensitivity85.8dB 2.83V/1m
Voice Coil Diameter1"
Resonant Frequency (Fs)62Hz
DC Resistance (Re)5.9Ω
Voice Coil Inductance (Le)0.27mH
Mechanical Q (Qms)2.21
Electromagnetic Q (Qes)0.59
Total Q (Qts)0.47
Compliance Equivalent Volume (Vas)0.3ft³
Mechanical Compliance of Suspension (Cms)0.74mm/N
BL Product (BL)5.9T·m
Diaphragm Mass Inc. Airload (Mms)9g
Maximum Linear Excursion (Xmax)3.5mm
Surface Area of Cone (Sd)89.9cm²
Cone MaterialPoly
Overall Outside Diameter5.99"
Baffle Cutout Diameter4.72"
Depth2.76"
# Mounting Holes6
Sealed Volume0.2ft³
Sealed F3104.4Hz
Vented Volume0.4ft³
Vented F357Hz
MONSTER DEAL
OF THE WEEK
$23.98 EACH
SAVE 20%
Lepai LP-2020BT Bluetooth Hi-Fi Audio Mini Class D Stereo Amplifier FM Media with Power Supply
