  • Lepai LP-2020BT Bluetooth Hi-Fi Audio Mini Class D Stereo Amplifier FM Media with Power Supply
Lepai
Part #310-3020
Lepai
Part #310-3020
Model: LP-2020BT
The LP-2020BT is the perfect solution for all your small amp/receiver needs. With its impressive range of features, including Bluetooth and multimedia player, line input, and FM radio, it has everything you need to enhance your audio experience. Whether you prefer manual sound adjustments or the convenience of the IR wireless remote, this device has got you covered. With its powerful output, it can easily fill a room with rich and immersive sound. Plus, its 12 VDC power input and mounting tabs make it versatile for use in vehicles or around the house. And with the included AC adapter, you can enjoy its benefits wherever you go. Upgrade your audio setup with the LP-2020BT and take your listening experience to the next level.
  • Multiple input functions to meet the needs of today's multimedia needs, but still has traditional Aux input and FM radio
  • Bluetooth 5.0 wireless connectivity with up to 50 ft. operating range
  • IR remote enables wireless control from your easy chair including EQ settings for Bluetooth, flash drive and FM functions
  • Manual bass and treble controls for more customized listening options
  • Flash drive repeat function continuously plays MP3, WAV, FLAC, APE and WMA files
  • 2 x 17W RMS fills a room with rich and immersive audio
  • CE and FCC certified amplifier with a UL listed, level VI and FCC certified power supply
Your Price: $29.98
MSRP: $49.99
Save $20.01 (40%)
Order in the next 1 hr 15 min to ship today. Details
Loaded with Functionality
The LP-2020BT is the ultimate small amp/receiver that is designed to cater to all your needs. Packed with a plethora of features, it offers unparalleled versatility and convenience. Whether you want to enjoy music wirelessly through Bluetooth, play your favorite media files, connect external devices through the line input, or even tune in to your favorite FM radio stations, this device has got you covered. Enjoy endless music stored onto a flash drive using the repeat all function.
  • Mode switch for LINE FM BT USB SD functions
  • Repeat all or repeat current track
  • Short press for previous track/FM channel, long press to decrease volume
  • Short press for next track/FM channel, long press to increase volume
  • Short press the play/pause, long press to search for stations in FM mode
  • Power On/Off
  • Bass
  • Treble
  • Volume
  • SD/USB input
  1. Left audio input
  2. Right audio input
  3. 3.5mm audio input
  4. FM antenna
  5. Right channel speaker output
  6. Left channel speaker output
  7. DC 12V3A power input
Complete Control
What sets the LP-2020BT apart is its ability to provide you with complete control over the sound. Easily adjust the sound manually with separate bass and treble controls to suit your preferences or use the IR wireless remote for added convenience with EQ settings for Bluetooth, Flash drive and FM. With its powerful output, this little powerhouse is capable of filling any room with rich and immersive audio.
Remote Control
  1. Power On/Off
  2. Repeat all or repeat current track
  3. Mode switch for LINE FM BT USB SD functions
  4. Choose channel, previous channel FM
  5. Select channel, next channel FM
  6. EQ for Bluetooth, FM and Flash drive modes
  7. Previous track
  8. Next track
  9. Stop/Play
  10. Long press volume down
  11. Long press volume up
  12. The number keys can be used in FM mode to enter the radio frequency to search
Versatility
Not only is the LP-2020BT feature-rich, but it is also incredibly versatile in terms of power options. Its 12 VDC power input enables you to install it permanently in your vehicle, making it a great solution for a simple car audio system. Alternatively, you can use it around the house with the included AC adapter, allowing you to enjoy high-quality audio in any room.
All These Features without Breaking the Bank
And let's not forget about the price. The LP-2020BT offers all these incredible features at an affordable cost. You don't have to break the bank to enjoy high-quality audio. Enjoy all these audio input options without compromising your budget.
So, why miss out on the opportunity to elevate your audio experience? The LP-2020BT is here to provide you with a complete audio solution that caters to all your needs. Whether you're on the road or at home, this exceptional device will take your music enjoyment to the next level. Don't wait any longer. Grab the LP-2020BT and immerse yourself in a world of superior sound.
Specifications: • Power output: 17 watts x 2 @ 4 ohms 500 mV 3% THD, 10 watts x 2 @ 4 ohms 200 mV 0.7% THD • Frequency response: 20 Hz-20,000 kHz +/- 3% • SNR: 80 dB @ 500 mV • Impedance: 4-8 ohms • Crosstalk: -59.7 dB • Amplifier input voltage: 12-14 VDC • Amplifier input amperage: 3A • Power supply input voltage: 100-240 VAC, 50/60 Hz • Power supply max input amperage: 800 mA • Power supply output voltage: 12 VDC @ 3A with 5 ft. cord • Amplifier topology: Class D • Bluetooth range: Up to 50 feet • Bluetooth 5.0 • Supported formats: SBC/MC (VS.I+BR+EDR+BLE) • Bluetooth name: LP-2020BT • Mounting Dimensions: 6.07" x 3.4" x 1.7" (154 x 85 x 43 mm) • Metal body dimensions with knobs and jacks: 6.07" W x 4.63" D x 1.7" H.
BrandLepai
ModelLP-2020BT
Part Number310-3020
UPC848864070681
Weight1.15
Power (RMS/Channel 8 ohms)0 - 25 Watts
Weight Range< 10 lbs.
Special FeaturesBluetooth
MONSTER DEAL
OF THE WEEK
$98.98 EACH
SAVE 40%
Dayton Audio DTA-PRO 100W Class D Bluetooth Amplifier with USB DAC IR Remote and Sub Output
