  • PRV Audio WG23-25 1" 100 x 40 Waveguide 1-3/8"-18 TPI
PRV Audio
Part #294-2912
PRV Audio
Part #294-2912
Model: WG23-25
Use the PRV Audio WG23-25 exponential horn to create small high efficiency speakers with 1-3/8"-18 TPI screw-on compression drivers. 100° x 40° coverage is perfect for speakers requiring increased horizontal dispersion and reduced vertical dispersion.
  • 100° x 40° dispersion pattern for wide horizontal dispersion
  • Acoustically loads compression drivers down to 600 Hz
  • Lightweight ABS construction with exponential flare
  • 1" throat diameter with 1-3/8"-18 TPI threads
Your Price: $9.91
Order in the next 9 hr 5 min to ship today. Details
PRV Audio's WG23-25 100° x 40° exponential horn is designed to project an expanded horizontal dispersion while also reducing floor and ceiling bounce. This horn is constructed of durable ABS plastic to keep cabinets as light as possible for easy transport. The standard 1-3/8"-18 TPI threading is compatible with many 1" compression drivers. Acoustic loading is maintained down to 600 Hz.
Specifications:• Horn type: Exponential • Minimum frequency: 600 Hz • Nominal dispersion: 100° H x 40° V • Throat diameter: 1" • Mounting type: 1-3/8"-18 TPI • Dimensions: 5.25" H x 10" W x 5.5" D • Cabinet cutout: 3.5" H x 6.5" W.
BrandPRV Audio
ModelWG23-25
Part Number294-2912
UPC799928735025
Weight0.4
ConstructionABS
Entry / Throat Diameter1"
Mounting Type1-3/8"-18 TPI
MONSTER DEAL
OF THE WEEK
$19.98 EACH
SAVE $10
