  • PRV Audio 3DF400/1800 Three-Way Crossover Board 400/1,800 Hz with Selectable Attenuation
PRV Audio
Part #294-2869
PRV Audio
Part #294-2869
Model: 3DF400/1800
Get your professional audio speaker cabinet up and running like new (or build your own custom speaker) with the PRV Audio 3DF400/1800 400 Hz, 1,800 Hz three-way crossover.
  • 4 or 8 ohm woofer impedance for use with single or dual woofer cabinets
  • Selectable attenuation for mids and highs
  • 6 dB/octave woofer low-pass slope, 12 dB/octave for midrange and tweeter
  • Made in Brazil
Your Price: $139.91
MSRP: $174.89
Save $34.98 (20%)
Expected back in stock any day
Alert Me When Available
PRV Audio's 3-way 3DF400/1800 crossover (with crossover points at 400 and 1,800 Hz) is designed to be used with passive (unpowered) speakers. Selectable 4 or 8-ohm woofer impedance and 6 dB/octave woofer low pass slops allow you to use this crossover with single and double woofer 3-way cabinets. High frequency level adjustments of 6, 7.5, and 9 dB and midrange frequency level matching of 0, 3, or 6 dB is provided.
High quality components are used throughout for longevity and great sound, and the impedance, as well as high frequency attenuation, is selected by convenient on-board jumpers. Made in Brazil.
Specifications: • Power handling: 950 watts RMS, 1,900 watts program power • Crossover points: 400 Hz low-pass 6 dB/octave slope for woofers, 400 to 1,800 Hz, 12 dB/octave band-pass for mids, 1,800 Hz, 12 dB/octave high-pass for compression drivers • Attenuation: 0, 3, or 6 dB for mids, 6, 7.5, or 9 dB for highs.
BrandPRV Audio
Model3DF400/1800
Part Number294-2869
UPC799928734608
Weight3.34
Crossover Type3-Way
