We use cookies to provide the best possible customer experience across this site, through third party ads and analysis of web data. By continuing you agree to our use of cookies and our overall privacy policy.
  • CONTACT US
  • SIGN IN
    SIGN IN
  • CART  (0)
    0 item(s) in your cart:
    Your cart is empty
CHECKOUT
CHECKOUT
Secure Shopping
SHOP
  • New Products
  • Shop by Brand
  • Home A/V
  • Speaker Components
  • Pro Audio
  • Car Audio
  • Electronic Parts
  • Connectors & Adapters
  • Tools & Supplies
  • Battery & Power
  • Wire & Cables
  • Novelty
DEALS
  • On Sale
  • Outlet Center
  • Special Buys
  • Open Box & Refurbished
  • Gift Certificates
PROFESSIONAL
  • Commercial Accounts
  • OEM/ODM Services
  • Business Forms
  • Education
  • Installer/Integrator Referral Network
  • Installer/Integrator Referral Sign-up
GET HELP
  • FAQs
  • Tech Support
  • Woofer Replacement Tool
  • Track My Order
  • Contact Us
LEARN
  • Resource Center
  • Customer Project Gallery
  • TechTalk Forum
  • PRV Audio DSP 2.4X 4-Channel Digital Signal Processor
Read 1 Review | 1 Question, 1 Answer or
PRV Audio
Part #294-3516
PRV Audio
Part #294-3516
Model: DSP 2.4X
4-Channel8-Channel
The PRV Audio DSP 2.4X is a versatile digital signal processor designed to enhance your car audio system with precise real-time adjustments. The DSP 2.4X is capable of making various adjustments, from crossover filters, graphic and parametric equalization, alignment, phase inversion, limiter, audio generator, and everything else you could need to enhance your audio system!
  • 2 audio inputs (A and B) and 4 independent outputs
  • 15-band graphic equalizer with 12 preset modes
  • Input and output parametric equalizers for fine-tuning
  • Butterworth and Linkwitz-Riley filters to precisely define your crossover function
  • Limiter with dynamic attack-release for speaker protection
  • High-accuracy delay and phase inversion capabilities
  • Integrated audio generator for testing and adjustments
  • Dayton Audio DSP-408 4x8 DSP Digital Signal Processor for Home and Car Audio
    Price:$179.98       Part #230-500
  • miniDSP C-DSP 8x12 V2.0 8 In 12 Out Automotive DSP
    Price:$849.98       Part #230-343
See all items in Digital Signal Processing
Your Price: $69.91
MSRP: $87.39
Save $17.48 (20%)
We'll send you an email when PRV Audio DSP 2.4X 4-Channel Digital Signal Processor is back in stock or available for preorder.
Share
Share
PRV Audio DSP 2.4X 4 Channel Digital Signal Processor
    Introducing the DSP 2.4X Digital Signal Processor from PRV Audio, designed to revolutionize the automotive sound market with cutting-edge technology. This processor enables a wide range of real-time signal adjustments, including crossover filters, graphic and parametric equalization, time alignment, phase inversion, limiters, audio generation, and more—elevating your audio system to new heights.
Featuring an LCD display and user-friendly interface, the DSP 2.4X makes real-time audio customization simple and intuitive. It includes 2 audio inputs (A and B) and 8 independent outputs, allowing you to assign the audio source (A, B, or A + B) for each output. The built-in equalization system includes a 15-band graphic equalizer, offering manual adjustment options or access to 12 presets such as Flat, Loudness, Bass Boost, Mid Bass, Treble Boost, Powerful, Electronic, Rock, Hip Hop, Pop, Vocal, and Pancadão.
For precise equalization adjustments, the DSP 2.4X is equipped with a Parametric Equalizer for both the input and output channels, offering gain control, specific frequency selection, and adjustable bandwidth. These features enable fine-tuning and detailed control over equalization for a fully customized audio experience. The Crossover function allows you to define cut-off frequencies, adjust attenuation rates, and select the filter topology for LowPass and HighPass filters. It supports Butterworth and Linkwitz-Riley configurations with slopes of 12, 18, 24, 36, or 48 dB per octave, ensuring precise frequency management tailored to your system's needs.
To protect amplifiers and loudspeakers, the DSP 2.4X incorporates a Limiter with a Dynamic Attack-Release system. This feature dynamically adjusts the attack and release parameters in real-time, ensuring consistent sound fidelity while providing reliable security for your audio equipment.
The DSP 2.4X offers advanced audio treatment features, including High Accuracy Delay for alignment, Phase Inversion, Independent Gain control per output, and Master Level adjustment for precise sound customization. For accurate measurements and system tuning, it includes an integrated Audio Generator with tone generation, frequency sweep, and Pink Noise capabilities.
Additional convenience features include Configuration Copy between output channels, allowing for efficient setup adjustments. The DSP 2.8X also supports Management functions, enabling you to Save and Load Settings to memory. A Security Password feature protects parameter settings from unauthorized editing, while a Marquee/Text Display and Language Selection add flexibility and user-friendly operation.
Sequencer Feature
Enables sequential activation of other devices using the remote trigger connection (REM) with a recommended cable size of at least 20 AWG. The sequencer includes three outputs (S1, S2, and S3) that are activated and deactivated sequentially based on the signal received from the remote input (REM IN). The interval between each output’s activation can be adjusted from 0 to 4 seconds. When set to 0 seconds, all three outputs are triggered simultaneously, with a 3-second delay following the remote input (REM IN) signal change.
  • Number of processors: (DSPs) 1
  • Input Channels: 2
  • Output Channels: 4
  • Output Gain: Yes
  • Master Level: 0 ~ 100%
  • Graphic Equalizer: 15 Band
  • Graphic Equalizer Presets: 12
  • Parametric Equalizer Input: 1
  • Parametric Equalizer Output: 4 / 1 per Channel
  • Routing: A,B / A+B
  • Crossover Butterworth (dB/8ª): 12/18/24/36/48
  • Crossover Linkwitz-Riley (dB/8ª): 12/18/24/36/48
  • Limiter: Yes
  • Automatic Attack/Release: Yes
  • Delay: 0 to 8 ms (275 cm)
  • Frequency Generator: 10Hz – 22kHz, Level -60 at 0dB
  • Frequency Scan: 10Hz – 22kHz / Level -60 at 0dB / Control of speed
  • Display: LCD16x2 Characters
  • Screen Saver: Text
  • Security Password: Yes
  • Frequency Response(+/-3dB): 10Hz @ 22.5kHz @ -1dB
  • Latency: 1.08ms
  • Signal to Noise Ratio (SNR): >90dB
  • Total Harmonic Distortion (THD): <0,01%
  • Channel Separation: > 80 dB
  • Maximum Input Voltage: 5,6 Vpp (+8,2 dBu)
  • Maximum Output Voltage: 5,6 Vpp (+8,2 dBu)
  • Supply Voltage: 9V to 16V DC
  • Dimensions (HxWxL): 1.45″ x 7.87″ x 3.97″
  • Weight: 1 lb.
BrandPRV Audio
ModelDSP 2.4X
Part Number294-3516
UPC810075521153
Weight1.15
  • PRV Audio DSP2.4X User's Manual
  • PRV Audio Manufacturer's Warranty
Our Company
  • About Parts Express
  • Careers
  • Retail Store – Springboro, OH
  • Press Releases
  • Brand Ambassador Program
  • Get Email Offers
  • Catalog & Sales Flyer
  • Speaker Design Competition
Orders & Returns
  • Track My Order
  • Free Shipping Offer
  • 60 Day No-Hassle Returns
  • Promotional Exclusions
Professional
  • OEM/ODM Services
  • Business Forms
  • Education
  • Installer/Integrator Referral Sign-Up
Community
  • TechTalk Forums
Get Connected
  • YouTube
  • Twitter
  • Instagram
  • Facebook
  • Pinterest
Customer Service
Live Chat
Contact Us
  • FAQs
  • Tech Support
  • Resource Center
  • Accessibility Statement
  • Customer Feedback
© 1996-2025 Parts Express All Rights Reserved
725 Pleasant Valley Dr.
Springboro, OH 45066 USA
  • Terms of Use
  • Privacy Policy
  • International Orders
  • Contact
  • Terms of Use
  • Privacy Policy
