  • miniDSP C-DSP 8x12 V2.0 8 In 12 Out Automotive DSP
miniDSP
Part #230-343
miniDSP
Part #230-343
Model: C-DSP 8x12 V2.0
The miniDSP C-DSP 8x12 high-end mobile/car audio next-generation processor provides pristine high-resolution audio at internal sample rates up to 192 kHz. Versatile inputs and output options in a compact, rugged enclosure, the C-DSP 8x12 is perfect for both simple stereo setups as well as multi-channel active systems.
  • 400 MHz 32-bit Sharc Floating point processor, up to 192 kHz processing with 32-bit DAC/ADC chipsets
  • Flexible DSP processing blocks, rear fill processing (L-R, L+R)
  • Remote control or preset/master & sub volume control
  • Fully differential balanced high and low level inputs with 12 analog outputs
  • Includes 1 x C-DSP processor, 1 x 1m USB cable, 1 x Control GUI plugin, 1 x 5m remote cable and remote module, 1 x C-DSP 8x12 plugin license
Your Price: $849.98
Order in the next 0 hr 1 min to ship today. Details
The C-DSP 8x12 is miniDSP's next-generation processor for high-end mobile/car audio. The powerful 400 MHz SHARC floating-point processor provides pristine high-resolution audio at internal sample rates up to 192 kHz. With a wealth of inputs and outputs in a compact, rugged enclosure, the C-DSP 8x12 is suitable for installations from simple stereo, through surround systems with subwoofer integration, up to advanced multichannel active systems. New to this upgraded version are the onboard 32-bit AKM converters that provide low noise and improved dynamic range to perfect your miniDSP experience.
The driverless USB interface is used to configure miniDSP's powerful but easy-to-use audio processing: parametric EQ on all inputs and outputs, compressors and adjustable time delay on all outputs, crossovers up to 48 dB/octave, and an advanced matrix mixer. Four complete processing configurations are stored in flash memory for instant recall with a wired or infrared remote.
Hardware features dedicated to the vehicle environment include an on-board isolated power supply, remote trigger input/output, a wired remote for dash or console mounting, and a microSD card slot for offline configuration and firmware updates.
DSP converter: Analog Devices ADSP21489 floating point DSP 32-bit AK4456(DAC), 32-bit AK5556(ADC)
Sample rate: 32-bit/192 kHz on CDSP 8x12 plugin
IO: 8 in / 12 out
Input connectors: 6 x high level terminal blocks, 6 x low level RCA, SPDIF, Toslink
Output connectors: 12 x RCA
SNR: 115 dB
THD+N: 0.0007%
Max input level: 8 or 12 Vrms high level / 4 or 2 Vrms low level
Max output level: 6 Vrms
Input impedance: 68 ohms high level, 10 kohms low level
Output impedance: 560 ohms
Calibration software: C-DSP 8x12 plugin
Filtering technology: IIR/FIR (depending on plugin)
DSP presets: Up to 4
Features: Impulse response correction, infrared remote learning, Win/Mac compatible, room EQ wizard
Power requirements: Isolated DC-DC conversion for car audio
Dimensions: 1.6" x 8.1" x 4.8"
BrandminiDSP
ModelC-DSP 8x12 V2.0
Part Number230-343
UPC848864061818
Weight3.1
