  • PRV Audio D4400Ti-Nd Neodymium 2" Titanium Compression Driver 8 Ohm 4-Bolt
PRV Audio
Part #294-2793
PRV Audio
Part #294-2793
Model: D4400Ti-Nd
With a powerful neodymium motor, the D4400Ti-Nd delivers everything you expect from the ferrite version but with half the weight and over 2.5" smaller diameter. The incredibly rigid and lightweight 4" diaphragm makes this an efficient and accurate high frequency horn driver.
  • Neodymium version of PRV Audio's flagship compression driver
  • Surprisingly smooth and natural response from 1,600 to 13,000 Hz
  • Low mass CCAW voice coil and titanium diaphragm for detailed response
  • Powerful neodymium motor provides extremely accurate diaphragm control
  • High efficiency combined with high power handling for incredible output capabilities
  • High sensitivity of 110 dB for efficiency
  • Rated AES power handling of 200 watts
Your Price: $199.91
MSRP: $249.89
Save $49.98 (20%)
Order in the next 1 hr 45 min to ship today. Details
PRV Audio D4400Ti-Nd 2" Exit High Frequency Compression Driver
    The D4400Ti-Nd offers a robust 4" titanium voice coil, ensuring both durability and precision. Its lightweight neodymium magnet significantly reduces the driver's weight, making it easier to install and integrate into various professional systems. With a sensitivity of 110 dB, this driver delivers efficient sound output with minimal distortion, even in high-demand settings.
    Designed to excel in large venues and professional environments, the D4400Ti-Nd’s wide frequency response ensures smooth and accurate reproduction of high frequencies. The bolt-on mounting design allows for secure attachment to standard horns, making installation straightforward and reliable. Combining advanced materials and a compact design, this driver is an exceptional choice for professional audio systems requiring high-fidelity sound and dependable performance.
  • Exit Throat Diameter 2” (50 mm)
  • Nominal impedance 8 Ohms
  • Rated AES Power Handling (RMS) 200 Watts
  • Program Power 400 Watts
  • Sensitivity 2.83V at 1m 110 dB
  • Recommended Hi Pass Crossover**:  1600 Hz**
    **For Full Power Handling **12db Per Octave Crossover
  • Frequency Response at -10dB 1,300 – 17,000 Hz
  • Voice Coil Diameter 4”(101.6 mm)
  • Voice Coil Wire CCAW
  • Voice Coil Former Material Kapton
  • Diaphragm Material Titanium
  • Flux Density 1.90 T
  • Magnet Material Neodymium
  • Overall Diameter 6.06” (154 mm)
  • Overall Depth 2.48” (63 mm)
  • Mounting Bolt Circle M6 x 4 4” (101.6 mm)
  • Net Weight: 8.82 lbs. (4 kg
BrandPRV Audio
ModelD4400Ti-Nd
Part Number294-2793
UPC602938021128
Weight8.9
Diaphragm MaterialTitanium
Exit Diameter2"
Mounting Type4-Bolt
Power Handling (RMS)200 Watts
MONSTER DEAL
OF THE WEEK
$98.98 EACH
SAVE 40%
Dayton Audio DTA-PRO 100W Class D Bluetooth Amplifier with USB DAC IR Remote and Sub Output
