PRV Audio D3220Ti-Nd 2" Titanium Neodymium Horn Compression Driver 8 Ohm 4-Bolt
Upgrade your speaker cabinets today using PRV Audio's D3220TiH-Nd 2" neodymium compression driver. High output and smooth frequency response allows you to use this horn driver in almost any high output audio application: pro, home, or car. Standard 4-bolt pattern and weighs less than 5 lbs.
- Kapton® former and titanium diaphragm for neutral sound
- Designed for high frequency use 1,600 to 19,000 Hz
- High 108 dB sensitivity with lightweight neodymium motor
- Four M6 bolt holes for secure horn coupling with included mounting bolts
- Spring-loaded speaker terminals
- Price:$109.95 Part #294-3386
We'll send you an email when PRV Audio D3220Ti-Nd 2" Titanium Neodymium Horn Compression Driver 8 Ohm 4-Bolt is back in stock or available for preorder.
