  • PRV Audio D4400Ti 2" Titanium Compression Driver 8 Ohm 4-Bolt
PRV Audio
Part #294-2792
PRV Audio
Part #294-2792
Model: D4400Ti
PRV Audio's D4400Ti 2" compression driver combines a massive motor with an incredibly rigid and lightweight 4" diaphragm to create an extremely efficient and accurate high frequency horn driver that has become PRV's flagship compression driver.
  • 4-inch CCAW voice coil wound on a Kapton former for exceptional durability and heat resistance
  • Frequency response range of 1,000 Hz to 17,000 Hz for clear high-frequency coverage
  • High efficiency combined with high power handling for incredible output capabilities
  • Advanced magnet and plate design for improved energy efficiency and reduced diaphragm deformation
  • Newly improved magnetic plate design provides higher sensitivity and lower distortion
Your Price: $129.91
MSRP: $162.39
Save $32.48 (20%)
Estimated back in stock 2/7/2025
Alert Me When Available
PRV Audio D4400Ti 2" Exit High Frequency Compression Driver
    The D4400Ti stands out with its ability to handle demanding audio scenarios, thanks to its high sensitivity and wide frequency response range. This allows it to reproduce crisp and dynamic high frequencies, ensuring excellent clarity for vocals and instruments in live performances and installed sound systems. Its improved magnet system not only enhances energy transfer but also reduces distortion, ensuring consistent audio quality even at high output levels.
    Built with rugged materials, the D4400Ti is engineered to provide long-lasting reliability in professional setups. The bolt-on mounting system simplifies installation, while the 4-inch voice coil ensures optimal heat dissipation and durability, even during extended use. Whether used in concert venues, auditoriums, or portable PA systems, the PRV Audio D4400Ti delivers outstanding performance, precision, and reliability for audio professionals.
  • Exit Throat Diameter: 2” (50 mm)
  • Nominal impedance: 8 Ohms
  • Rated AES Power Handling (RMS): 200 Watts
  • Program Power: 400 Watts
  • Sensitivity 2.83V at 1m: 110 dB
  • Recommended Hi Pass Crossover**: 1600 Hz**
    **For Full Power Handling **12db Per Octave Crossover
  • Frequency Response at -10dB: 1,000 – 17,000 Hz
  • Voice Coil Diameter: 4”(101.6 mm)
  • Voice Coil Wire: CCAW
  • Voice Coil Former Material: Kapton
  • Diaphragm Material: Titanium
  • Flux Density: 1.85 T
  • Magnet Material: Ferrite
  • Overall Diameter: 7.86” (199.75 mm)
  • Overall Depth: 3.18” (81 mm)
  • Mounting Bolt Circle: M6x4 4” (101.6 mm)
  • Net Weight: 19.20 lbs. (8.70 kg)
BrandPRV Audio
ModelD4400Ti
Part Number294-2792
UPC602938021104
Weight22.05
Diaphragm MaterialTitanium
Exit Diameter2"
Mounting Type4-Bolt
Power Handling (RMS)200 Watts
MONSTER DEAL
OF THE WEEK
$98.98 EACH
SAVE 40%
Dayton Audio DTA-PRO 100W Class D Bluetooth Amplifier with USB DAC IR Remote and Sub Output
