  • Neutrik NAC3F-TRUE1-S PowerCON Waterproof Female Power Out Cable Connecter UV Rated 6-12 mm Chuck
NEW Neutrik NAC3F-TRUE1-S PowerCON Waterproof Female Power Out Cable Connecter UV Rated 6-12 mm Chuck
Neutrik
Part #092-310
Neutrik
Part #092-310
Model: NAC3F-TRUE1-S
The powerCON TRUE1 is an exceptional solution designed specifically for harsh and demanding environments, making it ideal for a range of applications requiring robust AC voltage connectivity. When you need a reliable power connection, the powerCON TRUE1 serves as a reliable replacement for traditional appliance couplers, providing a superior rugged solution complemented by a reliable locking mechanism.
  • Heavy duty sealed power connector for harsh and demanding environment
  • Lockable single phase connector for safety
  • ENEC and VDE certified according to IEC 60320-1 and EN IEC 60320-1
  • Uses high impact UV-resistant materials for long life
  • UL and CSA Certified According to UL 60320-1 and CSA 22.2 No. 60320-1
  • True mains connector with breaking capacity (CBC) for protection
  • Unique NEUTRIK locking bushing and strain relief for cable diameters 6 mm to 12 mm (0.23 – 0.47 inches)
NEW $10.36
MSRP: $12.08
Save $1.72 (14%)
Quantity:Qty: 1-9 $10.36/ea
Quantity:Qty: 10-99 $9.84/ea
Quantity:Qty: 100+$9.32/ea
Order in the next 19 hr 50 min to ship today. Details
Take the Show Outside
The NAC3F-TRUE1-S connector features breaking capacity (CBC), allowing you to connect or disconnect under load or while live. This capability enhances flexibility and safety, ensuring breaking or reconnecting power will be quick and uneventful. Whether you are working in staging, broadcasting, or any other high-stakes environment, this connector will support your needs and help you succeed. Choose the powerCON TRUE1 today and experience the difference in reliable power connectivity!
Embrace the power of the powerCON TRUE1 for your next project—it’s built to perform and designed to last, providing you with confidence in demanding conditions. Use it with SJOOW AC wire to make cables that meet the needs for outdoor events.
Make sure when you take the show outside you use Neutrik PowerCON TRUE1 waterproof plugs to make sure the show goes on rain-or-shine.
BrandNeutrik
ModelNAC3F-TRUE1-S
Part Number092-310
UPC7613187022876
Weight0.09
ConfigurationNeutrik powerCON TRUE1
Current Rating20A
Power Connector TypeCable Mount
