  • Extendable Ratcheting Jewelers Screwdriver Kit
Part #360-139
Part #360-139
Add this extendable 12-in-1 professional small bit screwdriver set to your everyday tool box. The bit instantly expands to reach screws recessed up to 4" deep without sinking back into the handle until your ready.
  • Noise free gearless ratchet
  • Quickly extends to the length needed to reach recessed screws
  • Six double ended 4-3/4" bits for versatility
  • Internal metal shaft bit holder for extra torque and durability
  • Ends included: Phillips 00, 0, 1; Slot 1.5, 2.5, 3; Torx T6, T7, T8, T9; Hex 1.5 mm, 2.0 mm
Your Price: $9.98
MSRP: $11.99
Save $2.01 (17%)
Carry fewer bits and reach more recessed screws with this 12-in-1 professional tool set. Each bit is double ended and reaches recessed screws up to 4"deep. Easily adjust each bit to the desired length by pulling it out of the handle. To retract the bit, lift the retaining collar and push the bit back into the handle to the desired length.
The metal bit slides back and forth into a metal shaft inside the handle. The metal shaft helps deliver more torque compared to other mini screwdriver sets with a plastic shaft. Hard molded black ABS holds the metal shaft in place and the red rubber ribs create extra grip.
Use the 4-3/4" handle's silent ratcheting action to easily tighten or loosen screws or lock it for normal operation. The top of the handle rotates independently from the main handle to help keep pressure on the screw, with the palm of your hand, so it doesn't strip.
Part Number360-139
UPC848864059990
Weight0.4
