  • LaVoce WAN153.00 15" Neodymium Woofer 8 Ohm
LaVoce
Part #293-721
LaVoce
Part #293-721
Model: WAN153.00
The LaVoce WAN153.00 is an impressive 15" woofer that features a robust aluminum basket providing exceptional cooling. The excellent 98.5 dB sensitivity is perfect for mating to other high-efficiency drivers.
  • FEM optimized Neodymium motor and suspensions
  • Optimized cooling system for reliable performance
  • High 98.5 dB sensitivity
  • Resonance-free, heavy-duty aluminum basket demonstrates excellent build quality
  • Weighs only 12.7 lbs. (5.8 kg)
Your Price: $229.00
MSRP: $341.79
Save $112.79 (33%)
Order in the next 16 hr 52 min to ship today. Details
Only 1 In Stock
The LaVoce WAN153.00 is an impressive 15" woofer that features a robust aluminum basket providing exceptional cooling. The excellent 98.5 dB sensitivity is perfect for mating to other high-efficiency drivers. The gasket on this driver allows it to be rear mounted easily, providing additional installation flexibility. To add to the versatility of this driver, the cone has been treated to be waterproof, making it ideal for outdoor cabinets.
BrandLavoce
ModelWAN153.00
Part Number293-721
UPC848864057439
Weight18.55
Nominal Diameter15"
Bolt Circle Diameter14.69
Power Handling (RMS)500 Watts
Frequency Response45 to 3,000Hz
Sensitivity98.5dB 2.83V/1m
Voice Coil Diameter3"
Resonant Frequency (Fs)43Hz
DC Resistance (Re)4.7Ω
Voice Coil Inductance (Le)0.75mH
Mechanical Q (Qms)9.5
Electromagnetic Q (Qes)0.43
Total Q (Qts)0.41
Compliance Equivalent Volume (Vas)4.84ft³
BL Product (BL)17.3T·m
Diaphragm Mass Inc. Airload (Mms)100g
Maximum Linear Excursion (Xmax)7mm
Surface Area of Cone (Sd)850cm²
Cone MaterialTreated Paper
Surround MaterialCloth
Voice Coil Wire MaterialCCA
Voice Coil FormerFiberglass
Magnet MaterialNeodymium
Overall Outside Diameter15.47"
Baffle Cutout Diameter13.93"
Depth6.81"
Sealed Volume2ft³
Sealed F362.1Hz
Vented Volume4.25ft³
Vented F345Hz
