  • LaVoce WAF153.00 15" Ferrite Woofer 8 Ohm
LaVoce
Part #293-720
LaVoce
Part #293-720
Model: WAF153.00
The LaVoce WAF153.00 is an impressive 15" woofer that features an impressive aluminum basket which provides exceptional cooling. The excellent 99 dB sensitivity is perfect for mating to other high-efficiency drivers.
  • FEM optimized Ferrite motor and suspensions
  • Optimized cooling system for reliable performance
  • Impressive 99 dB sensitivity
  • Resonance-free, heavy-duty aluminum basket demonstrates excellent build quality
Your Price: $209.00
MSRP: $311.94
Save $102.94 (33%)
Order in the next 16 hr 45 min to ship today. Details
Only 3 In Stock
The LaVoce WAF153.00 is an impressive 15" woofer that features an impressive aluminum basket which provides exceptional cooling. The excellent 99 dB sensitivity is perfect for mating to other high-efficiency drivers. The gasket on this driver allows it to be rear mounted easily, providing additional installation flexibility. To add to the versatility of this driver, the cone has been treated to be waterproof, making it ideal for outdoor cabinets.
BrandLavoce
ModelWAF153.00
Part Number293-720
UPC848864057422
Weight25.25
Nominal Diameter15"
Bolt Circle Diameter14.69
Power Handling (RMS)500 Watts
Frequency Response40 to 3,000Hz
Sensitivity99dB 2.83V/1m
Voice Coil Diameter3"
Resonant Frequency (Fs)43Hz
DC Resistance (Re)4.7Ω
Voice Coil Inductance (Le)0.9mH
Mechanical Q (Qms)9
Electromagnetic Q (Qes)0.39
Total Q (Qts)0.37
Compliance Equivalent Volume (Vas)5.16ft³
Mechanical Compliance of Suspension (Cms)0.14mm/N
BL Product (BL)17.8T·m
Diaphragm Mass Inc. Airload (Mms)99g
Maximum Linear Excursion (Xmax)7mm
Surface Area of Cone (Sd)855cm²
Cone MaterialTreated Paper
Surround MaterialCloth
Voice Coil Wire MaterialCCA
Voice Coil FormerFiberglass
Overall Outside Diameter15.47"
Baffle Cutout Diameter13.93"
Depth6.87"
Sealed Volume1.75ft³
Sealed F368Hz
Vented Volume3.5ft³
Vented F350.4Hz
