  • JBL Selenium 8M PRO 8" 300 Watt Professional Mid-Bass 8 Ohm
3 Questions, 13 Answers or
JBL Selenium
Part #264-477
JBL Selenium
Part #264-477
Model: 8MPRO
The JBL Selenium 8M PRO is an 8-inch professional mid-bass speaker designed to deliver exceptional sound clarity and performance. With a robust 300 watts RMS power handling and 8-ohm impedance, this speaker provides precise, dynamic mid-bass frequencies. Ideal for professional audio systems and high-quality home sound setups, the 8M PRO combines advanced acoustic engineering with durable construction to ensure superior audio quality and reliability.
  • 300 watts RMS power handling
  • 8-inch diameter for enhanced mid-bass response
  • 8-ohm impedance for versatile compatibility
  • High sensitivity for efficient sound reproduction
  • Durable construction for long-lasting performance
Your Price: $179.99
Order in the next 6 hr 55 min to ship today. Details
The JBL Selenium 8M PRO is designed to handle up to 300 watts of continuous power, ensuring it can deliver high sound pressure levels without distortion. This high power capacity makes it suitable for demanding audio environments, providing robust and consistent performance. Whether used in professional PA systems or high-fidelity home theaters, this mid-bass speaker delivers powerful and reliable audio output.
With an 8-inch cone, the 8M PRO excels at producing precise and impactful mid-bass frequencies. This size allows for accurate sound reproduction, enhancing the clarity and detail of the audio. Perfect for vocal-heavy music genres and detailed soundtracks, this speaker adds depth and accuracy to any sound system.
The 8-ohm impedance of the 8M PRO ensures compatibility with a wide range of amplifiers and audio systems. This standard impedance allows for easy integration into existing setups, providing flexibility and convenience. Whether you're upgrading an existing system or designing a new one, the 8M PRO fits seamlessly to deliver optimal performance.
The high sensitivity of the 8M PRO allows it to produce loud sound levels with minimal power input. This efficiency makes it suitable for various amplifier types and power ratings, ensuring excellent performance across different audio setups. High sensitivity also helps maintain audio clarity and detail at different volume levels, enhancing the overall listening experience.
Built with high-quality materials, the JBL Selenium 8M PRO is designed for durability and long-lasting performance. Its robust construction ensures it can withstand the demands of continuous use, making it a reliable component in both professional and home audio systems. The durable design helps maintain sound quality over time, providing consistent and reliable performance for years to come.
BrandSelenium
Model8MPRO
Part Number264-477
UPC7896359555048
Weight8
Nominal Diameter8"
Bolt Circle Diameter7.638
Power Handling (RMS)300 Watts
Power Handling (MAX)600 Watts
Frequency Response80 to 6000Hz
Sensitivity94.5dB 2.83V/1m
Resonant Frequency (Fs)111.1Hz
DC Resistance (Re)5.5Ω
Voice Coil Inductance (Le)0.62mH
Mechanical Q (Qms)8.17
Electromagnetic Q (Qes)0.67
Total Q (Qts)0.62
Compliance Equivalent Volume (Vas)0.31ft³
Diaphragm Mass Inc. Airload (Mms)20.91g
Maximum Linear Excursion (Xmax)4.4mm
Surface Area of Cone (Sd)249.9cm²
Cone MaterialPaper
Surround MaterialCloth
Overall Outside Diameter8.228"
Baffle Cutout Diameter7.205"
Depth3.78"
