  • JBL Selenium 10M PRO 10" 350 Watt Professional Mid-Bass 8 Ohm
NEW JBL Selenium 10M PRO 10" 350 Watt Professional Mid-Bass 8 Ohm
3 Questions, 13 Answers or
JBL Selenium
Part #264-478
JBL Selenium
Part #264-478
Model: 10MPRO
The JBL Selenium 10M PRO is a high-performance 10-inch mid-bass speaker engineered for professional audio applications. With a powerful 350 watts RMS power handling and 8-ohm impedance, this speaker delivers clear, dynamic mid-bass frequencies. Perfect for professional sound systems and premium home audio setups, the 10M PRO combines advanced acoustic technology with robust construction to ensure superior sound quality and durability.
  • 350 watts RMS power handling
  • 10-inch diameter for enhanced mid-bass response
  • 8-ohm impedance for versatile compatibility
  • High sensitivity for efficient sound reproduction
  • Durable construction for long-lasting performance
NEW $249.99
Order in the next 3 hr 44 min to ship today. Details
The JBL Selenium 10M PRO is designed to handle up to 350 watts of continuous power, ensuring it can produce high sound pressure levels without distortion. This high power capacity makes it ideal for demanding audio environments, providing robust and consistent performance. Whether used in professional PA systems or high-fidelity home theaters, this mid-bass speaker delivers powerful and reliable audio output.
With a 10-inch cone, the 10M PRO excels at producing precise and impactful mid-bass frequencies. This larger size allows for greater air movement, enhancing the clarity and depth of the audio. Perfect for vocal-heavy music genres and detailed soundtracks, this speaker adds richness and accuracy to any sound system.
The 8-ohm impedance of the 10M PRO ensures compatibility with a wide range of amplifiers and audio systems. This standard impedance allows for easy integration into existing setups, providing flexibility and convenience. Whether you're upgrading an existing system or designing a new one, the 10M PRO fits seamlessly to deliver optimal performance.
The high sensitivity of the 10M PRO allows it to produce loud sound levels with minimal power input. This efficiency makes it suitable for various amplifier types and power ratings, ensuring excellent performance across different audio setups. High sensitivity also helps maintain audio clarity and detail at different volume levels, enhancing the overall listening experience.
Built with high-quality materials, the JBL Selenium 10M PRO is designed for durability and long-lasting performance. Its robust construction ensures it can withstand the demands of continuous use, making it a reliable component in both professional and home audio systems. The durable design helps maintain sound quality over time, providing consistent and reliable performance for years to come.
BrandSelenium
Model10MPRO
Part Number264-478
Weight15.25
Nominal Diameter10"
Bolt Circle Diameter9.567
Power Handling (RMS)350 Watts
Power Handling (MAX)700 Watts
Frequency Response80 to 7000Hz
Sensitivity97dB 2.83V/1m
Resonant Frequency (Fs)72.4Hz
DC Resistance (Re)5.57Ω
Voice Coil Inductance (Le)0.64mH
Mechanical Q (Qms)10.34
Electromagnetic Q (Qes)0.37
Total Q (Qts)0.36
Compliance Equivalent Volume (Vas)0.97ft³
Diaphragm Mass Inc. Airload (Mms)32.68g
Maximum Linear Excursion (Xmax)2.7mm
Surface Area of Cone (Sd)363cm²
Cone MaterialPaper
Surround MaterialCloth
Overall Outside Diameter10.236"
Baffle Cutout Diameter8.976"
Depth4.685"
Vented Volume1.1ft³
Vented F390Hz
MONSTER DEAL
OF THE WEEK
$14.98 EACH
SAVE 25%
Dayton Audio Boost Mini Portable Bluetooth Speaker Black
