  • JBL Selenium 12M PRO 12" 700 Watt Professional Mid-Bass 8 Ohm
NEW JBL Selenium 12M PRO 12" 700 Watt Professional Mid-Bass 8 Ohm
3 Questions, 13 Answers or
JBL Selenium
Part #264-479
JBL Selenium
Part #264-479
Model: 12MPRO
The JBL Selenium 12M PRO is a top-tier 12-inch mid-bass speaker designed to deliver outstanding audio performance for professional applications. With an impressive 700 watts RMS power handling and 8-ohm impedance, this speaker provides powerful, clear, and dynamic mid-bass frequencies. Ideal for professional sound systems and high-quality home audio setups, the 12M PRO combines cutting-edge technology with durable construction to ensure superior sound quality and reliability.
  • 700 watts RMS power handling
  • 12-inch diameter for robust mid-bass response
  • 8-ohm impedance for versatile compatibility
  • High sensitivity for efficient sound reproduction
  • Durable construction for long-term performance
NEW $299.99
Order in the next 3 hr 44 min to ship today. Details
The JBL Selenium 12M PRO is designed to handle up to 700 watts of continuous power, ensuring it can deliver high sound pressure levels without distortion. This high power capacity makes it perfect for demanding audio environments, providing robust and consistent performance. Whether used in professional PA systems or high-fidelity home theaters, this mid-bass speaker delivers powerful and reliable audio output.
With a 12-inch cone, the 12M PRO excels at producing deep and impactful mid-bass frequencies. This larger size allows for greater air movement, enhancing the richness and depth of the audio. Perfect for vocal-heavy music genres and detailed soundtracks, this speaker adds warmth and precision to any sound system.
The 8-ohm impedance of the 12M PRO ensures compatibility with a wide range of amplifiers and audio systems. This standard impedance allows for easy integration into existing setups, providing flexibility and convenience. Whether you're upgrading an existing system or designing a new one, the 12M PRO fits seamlessly to deliver optimal performance.
The high sensitivity of the 12M PRO allows it to produce loud sound levels with minimal power input. This efficiency makes it suitable for various amplifier types and power ratings, ensuring excellent performance across different audio setups. High sensitivity also helps maintain audio clarity and detail at different volume levels, enhancing the overall listening experience.
Built with high-quality materials, the JBL Selenium 12M PRO is designed for durability and long-lasting performance. Its robust construction ensures it can withstand the demands of continuous use, making it a reliable component in both professional and home audio systems. The durable design helps maintain sound quality over time, providing consistent and reliable performance for years to come.
BrandSelenium
Model12MPRO
Part Number264-479
UPC7896359555062
Weight16.45
Nominal Diameter12"
Bolt Circle Diameter11.496
Power Handling (RMS)700 Watts
Power Handling (MAX)1400 Watts
Frequency Response70 to 5000Hz
Sensitivity97dB 2.83V/1m
Resonant Frequency (Fs)59.3Hz
DC Resistance (Re)5.65Ω
Voice Coil Inductance (Le)0.67mH
Mechanical Q (Qms)10.71
Electromagnetic Q (Qes)0.4
Total Q (Qts)0.38
Compliance Equivalent Volume (Vas)1.96ft³
Diaphragm Mass Inc. Airload (Mms)51.86g
Maximum Linear Excursion (Xmax)2.4mm
Surface Area of Cone (Sd)530.93cm²
Cone MaterialPaper
Surround MaterialCloth
Overall Outside Diameter12.264"
Baffle Cutout Diameter10.906"
Depth5.197"
Vented Volume1.5ft³
Vented F380Hz
MONSTER DEAL
OF THE WEEK
$14.98 EACH
SAVE 25%
Dayton Audio Boost Mini Portable Bluetooth Speaker Black
