  • ICEpower 300A1 Class D Amplifier Module 1 x 300W
Read 1 Review or
ICEpower
Part #326-266
ICEpower
Part #326-266
Read 1 Review or
The 300A1 is the amplifier section of the 300AS1. It is a great sounding 1x 300W class D amplifier which can be powered from the DC hanger bus of the 300AS1. This makes it great for creating 2-way and 3-way active speakers with the 300AS1.
  • Powered by 300AS1 and 500ASP eliminating additional power supplies
  • JST jacks make it easy to receive/send out voltage from/to compatible ICEpower modules
  • ICEpower's patented COM modulation and MECC control techniques ensure excellent audio performance
  • High current output stages, designed to comfortably drive any speaker load from 2.5 ohms and up
  • Overload and thermal protection circuits for long lasting performance
Your Price: $79.98
All-In-One Fanless AMP & Power Supply Board
The ICEpower 300A1 is a "hanger" amp module powered by the ICEpower DC Bus integrated in the ICEpower 300AS1 and 500ASP amp modules. These two amp modules handle up to two additional ICEpower300A1 amplifier modules from the integrated power supply. This full compatibility with these ICEpower modules offers a flexible and powerful building block concept for multi-way and multi-channel audio system design. The optional wiring kit (sold separately) enables you to plug into the 300AS1 board with JST connectors for quick installation.
ICEpower power supply amp boards are only available in the USA from Parts Express. Parts Express ships out each order the same day if placed before 4 pm EST M-F. This makes it easier than ever to acquire ICEpower amp modules for your projects, and continental USA DIYs and OEMs save money by eliminating international shipping cost.
Note:Requires the 326-198 ICEpower Amplifier Module 300A1 Wiring Harness Kitfor full stand-alone functionality (sold separately).
Specifications: • Wattage output: 1 x 300W RMS @ 4 ohms 1% THD+N, 20-20,000 Hz • Frequency response: 20-20,000 Hz all loads • Dynamic range: 113 dB • Total efficiency: 90% @ 300W 4 ohm • Input voltage: 22-55 VDC • Maximum output current limit: 20A • Dimensions: 4.22" W x 2.2" D x 1.6" H.
BrandICEpower
Model300A1
Part Number326-266
UPC848864074399
Weight0.55
Board Type1 Channel Mono Amp
Power (RMS/Channel 8 ohms)101 - 250 Watts
