  • Stahl Tools STSSVT Variable Temperature Soldering Iron Station
Stahl Tools
Part #374-100
Stahl Tools
Part #374-100
Model: STSSVT
The Stahl Tools STSSVT variable temperature soldering station was designed to exceed the expectations of veteran technicians -- at a price that's appealing to the electronics hobbyist.
  • On/off switch with "power-on" indicator light showing when the iron is hot
  • Variable 302°F to 842°F heat setting to match specific soldering needs
  • cTUVus listed for safety and performance
  • Cushioned rubber grip for extended comfortable use
  • Replaceable tips provide additional functionality
  • Quality performance at a discount price
Your Price: $19.98
MSRP: $31.99
Save $12.01 (38%)
Quantity:Qty: 1-9 $19.98/ea
Quantity:Qty: 10+$18.98/ea
Order in the next 3 hr 4 min to ship today. Details
Make connections that last! A Stahl Tools STSSVT variable temperature soldering station provides the adjustability demanded by professionals, but offers it at a price that enables anyone to solder better. Total control over a soldering iron's heat is one sure way of making perfect electronic terminations every time, no matter the job's size.
Many different soldering tasks are accomplished easily by using the STSSVT's adjustable 5 to 40 watt (150°C to 450°C temperature) adjustment. The lightweight pencil design features a fatigue-reducing rubber grip, and a Bakelite-ringed holder keeps the iron at the ready. A field replaceable, precision ground, iron-plated solid copper tip provides maximum heat transfer, minimizing cold solder joints. Includes 1.5 mm conical soldering tip and cleaning sponge. Additional tips available for a variety of soldering applications. Stahl Tools—The Technician's Friend™.
Tip Replacement and Dressing:
Tip replacement or cleaning should be done only when the iron is at room temperature. The tip can be changed or replaced simply by unscrewing the knurled nut from the barrel assembly. The station must be switched off and allowed to cool before and during this operation, as damage may result if the system is left on without the tip installed. After removing the tip, blow out any oxide dust that may have formed in the tip retaining area of the barrel. Be careful to avoid getting debris in your eyes. Replace the tip and screw the retaining knurled nut onto the barrel assembly; tighten only finger-tight. To avoid burning your fingers, pliers should only be used to tighten the nut if it becomes loose when the iron is hot. Care should be taken not to overtighten, as this can damage the element.
General Cleaning:
The outer case of the iron or station may be cleaned with a damp cloth using a small amount of liquid detergent. Never submerse the unit in liquid or allow any liquid to enter the case of the station. Never use solvent to clean the case.
Maintenance:
The iron should be placed in its stand when not in use. If the supply cord becomes damaged, it must be replaced by a qualified service technician.
BrandStahl Tools
ModelSTSSVT
Part Number374-100
UPC844632077272
Weight1.75
