  • Goldwood GW-8024 8" Butyl Surround Woofer 4 Ohm
Goldwood
Part #290-356
Goldwood
Part #290-356
Model: GW-8024
The GW-8024 4 ohm woofer from Goldwood's Malibu series is ideal for replacing and upgrading old, worn out drivers. They all feature a polypropylene cone, vented pole piece, foam gasket, soft poly dust cap, and stamped steel frame.
  • Polypropylene cone and rubber surround resist fatigue
  • Designed for optimum response in sealed enclosures and free air use
  • Vented pole piece for reduced compression noise
Your Price: $31.18
MSRP: $50.99
Save $19.81 (39%)
Order in the next 0 hr 47 min to ship today. Details
Only 1 In Stock
More due any day
Butyl rubber surrounds are superior to foam in two important ways. First, the butyl rubber resists moisture and will not dry rot, providing years of service. Second, the rubber surround, due to its superior damping characteristics will greatly reduce cone break up and ensure low distortion. These woofers are ideal for replacing and upgrading old, worn out drivers. They all feature a polypropylene cone, vented pole piece, foam gasket, soft poly dust cap, and stamped steel frame.
BrandGoldwood
ModelGW-8024
Part Number290-356
UPC643420100297
Weight3.45
Nominal Diameter8"
Bolt Circle Diameter7.75
Power Handling (RMS)100 Watts
Power Handling (MAX)190 Watts
Frequency Response35 to 2,500Hz
Sensitivity89.6dB 2.83V/1m
Voice Coil Diameter1.5"
Resonant Frequency (Fs)44.1Hz
DC Resistance (Re)3.7Ω
Voice Coil Inductance (Le)0.4mH
Mechanical Q (Qms)3.42
Electromagnetic Q (Qes)0.93
Total Q (Qts)0.73
Compliance Equivalent Volume (Vas)1.08ft³
Mechanical Compliance of Suspension (Cms)0.46mm/N
BL Product (BL)5.61T·m
Diaphragm Mass Inc. Airload (Mms)28.5g
Surface Area of Cone (Sd)218.2cm²
Cone MaterialPoly
Overall Outside Diameter8"
Baffle Cutout Diameter7.25"
Depth3.625"
Sealed Volume1ft³
Sealed F352.6Hz
Vented Volume1.38ft³
Vented F337.2Hz
