  • Goldwood GW-6024 6-1/2" Butyl Surround Woofer 4 Ohm
Goldwood
Part #290-351
Goldwood
Part #290-351
Model: GW-6024
These woofers are ideal for replacing and upgrading old, worn out drivers. They all feature a polypropylene cone, vented pole piece, foam gasket, soft poly dust cap, and stamped steel frame.
Your Price: $26.38
MSRP: $42.99
Save $16.61 (39%)
Order in the next 0 hr 40 min to ship today. Details
Butyl rubber surrounds are superior to foam in two important ways. First, the butyl rubber resists moisture and will not dry rot, providing years of service. Second, the rubber surround, due to its superior damping characteristics will greatly reduce cone break up and ensure low distortion. These woofers are ideal for replacing and upgrading old, worn out drivers. They all feature a polypropylene cone, vented pole piece, foam gasket, soft poly dust cap, and stamped steel frame.
BrandGoldwood
ModelGW-6024
Part Number290-351
UPC643420100273
Weight3.3
Nominal Diameter6-1/2"
Power Handling (RMS)90 Watts
Power Handling (MAX)170 Watts
Frequency Response29 to 4,800Hz
Sensitivity89.5dB 2.83V/1m
Voice Coil Diameter1.5"
Resonant Frequency (Fs)53.7Hz
DC Resistance (Re)3.6Ω
Voice Coil Inductance (Le)0.4mH
Mechanical Q (Qms)3.05
Electromagnetic Q (Qes)0.71
Total Q (Qts)0.57
Compliance Equivalent Volume (Vas)0.42ft³
Mechanical Compliance of Suspension (Cms)0.46mm/N
BL Product (BL)5.72T·m
Diaphragm Mass Inc. Airload (Mms)19.1g
Surface Area of Cone (Sd)136.35cm²
Cone MaterialPoly
Overall Outside Diameter6.5"
Baffle Cutout Diameter5.625"
Depth3.25"
Sealed Volume0.45ft³
Sealed F374.8Hz
Vented Volume0.9ft³
Vented F343.5Hz
