  • Goldwood GW-1248 12" Butyl Surround Woofer 8 Ohm
Goldwood
Part #290-365
Goldwood
Part #290-365
Model: GW-1248
These woofers are ideal for replacing and upgrading old, worn out drivers. They all feature a polypropylene cone, vented pole piece, foam gasket, soft poly dust cap, and stamped steel frame.
  • Perfect replacement woofer for many old acoustic suspension speaker systems
  • With a vented 2" voice coil this driver can handle 150 watts RMS
  • The bumped back plate allows for short periods of over excursion
  • Capable of impressive low frequency response in larger sealed enclosures
Your Price: $55.18
MSRP: $89.99
Save $34.81 (39%)
Butyl rubber surrounds are superior to foam in two important ways. First, the butyl rubber resists moisture and will not dry rot, providing years of service. Second, the rubber surround, due to its superior damping characteristics will greatly reduce cone break up and ensure low distortion. These woofers are ideal for replacing and upgrading old, worn out drivers. They all feature a polypropylene cone, vented pole piece, foam gasket, soft poly dust cap, and stamped steel frame.
BrandGoldwood
ModelGW-1248
Part Number290-365
UPC643420100341
Weight7.8
Nominal Diameter12"
Power Handling (RMS)150 Watts
Power Handling (MAX)290 Watts
Frequency Response30 to 1,500Hz
Sensitivity87dB 2.83V/1m
Voice Coil Diameter2"
Resonant Frequency (Fs)33.3Hz
DC Resistance (Re)7.1Ω
Voice Coil Inductance (Le)0.6mH
Mechanical Q (Qms)3.3
Electromagnetic Q (Qes)1.3
Total Q (Qts)1
Compliance Equivalent Volume (Vas)3.66ft³
Mechanical Compliance of Suspension (Cms)0.26mm/N
BL Product (BL)10T·m
Diaphragm Mass Inc. Airload (Mms)88.2g
Surface Area of Cone (Sd)525.9cm²
Cone MaterialPoly
Overall Outside Diameter12"
Baffle Cutout Diameter11"
Depth5.1875"
Sealed Volume2ft³
Sealed F340.5Hz
