  • GRS 18PT-8 18" Paper Cone Professional Woofer with 3" Voice Coil 8 Ohm
GRS
Part #292-810
GRS
Part #292-810
Model: 18PT-8
The GRS 18PT-8 18” professional paper cone woofer will deliver high output bass response without breaking the bank. Packed with features like a 3” voice coil, inductance reducing copper cap, under spider venting, and gap vents; this driver is built for high performance, low distortion, and incredible reliability. Whether you need a drop-in replacement for a worn-out professional subwoofer or are working on a completely new design, the 18PT-8 is the perfect driver for budget builds.
  • Lightweight ribbed paper cone allows high efficiency with minimal resonance
  • 3” diameter voice coil on heat resistant Kapton former handles up to 350 watts RMS
  • Great displacement capability is ideal for high output subwoofer designs
  • Extensive venting keeps cool air flowing across the voice coil to minimize power compression
  • Inductance lowering copper cap reduces distortion and extends high frequency response
  • Spring-loaded push-button terminals makes wire connections quick and easy
  • Foam front gasket ensures an airtight seal for rear mount installations
Your Price: $59.42
MSRP: $90.99
Save $31.57 (35%)
156In Stock
Engineered for high output with powerful low frequency extension, the 18PT-8 18” professional woofer is ideal for use in large low-cost sound systems. Packed with features you would expect from much more expensive drivers, the 18PT-8 is built for low distortion and reliability even when pushed to its limit. The lightweight reinforced paper cone has excellent damping properties, minimizing unwanted resonances, and the ribbed surface controls cone breakup to ensure smooth response all the way up to 1,000 Hz. Driving the cone is a 3” diameter dual-layer voice coil that is wound on a heat resistant polyimide former to handle up to 350 watt RMS. Extensive venting through frame, pole piece, and magnetic gap cools the voice coil to prevent thermal runaway and lower power compression during long sessions at high power. With a copper cap on the pole piece keeping inductance under control, you can ensure that the 18PT-8 will provide low distortion throughout its useable bandwidth. Whether you need a drop-in replacement for a blown professional subwoofer, or are designing a new system, the 18PT-8 is the ideal choice if you want high impact low frequency response without spending a fortune.
BrandGRS
Model18PT-8
Part Number292-810
UPC848864066844
Weight19.8
Nominal Diameter18"
Bolt Circle Diameter17.59
Power Handling (RMS)350 Watts
Power Handling (MAX)700 Watts
Frequency Response25 to 4,000Hz
Sensitivity93dB 2.83V/1m
Voice Coil Diameter3"
Resonant Frequency (Fs)23Hz
DC Resistance (Re)6.9Ω
Voice Coil Inductance (Le)1.9mH
Mechanical Q (Qms)9.59
Electromagnetic Q (Qes)0.58
Total Q (Qts)0.54
Compliance Equivalent Volume (Vas)16.8ft³
Mechanical Compliance of Suspension (Cms)0.22mm/N
BL Product (BL)19.5T·m
Diaphragm Mass Inc. Airload (Mms)218g
Maximum Linear Excursion (Xmax)6.8mm
Surface Area of Cone (Sd)1234cm²
Surround MaterialCloth
Overall Outside Diameter18.07"
Baffle Cutout Diameter16.65"
Depth7.48"
Sealed Volume3.75ft³
Sealed F341.6Hz
Vented Volume6.75ft³
Vented F332.1Hz
MONSTER DEAL
OF THE WEEK
$34.98 EACH
SAVE 22%
Lepai LP-168HA 2.1 2x40W Mini Amplifier + 1x68W Sub Output
