  • GRS 12SFPC-W 12" Square Frame Paper Cone Woofer White
GRS
Part #290-914
GRS
Part #290-914
Model: 12SFPC-W
A perfect replacement woofer for classic hi-fi loudspeakers! The oversized decorative squared-off frame accommodates a wide variety of OEM driver cutouts.
  • Attractive square stamped steel frame
  • Smooth response and hefty bass output
  • Treated paper cone
  • Foam half roll edge
  • Choice of white or black cone
Your Price: $24.98
MSRP: $69.99
Save $45.01 (64%)
Quantity:Qty: 1-3 $24.98/ea
Quantity:Qty: 4+$22.48/ea
151In Stock
A perfect replacement woofer for classic hi-fi loudspeakers! The oversized decorative squared-off frame accommodates a wide variety of OEM driver cutouts. Smooth response and generous Xmax ensure optimum performance, and the use of modern materials and adhesives means your "experienced" speaker system will serve for many more years to come. Also great for DIY projects. Available in white or black cone versions.
BrandGRS
Model12SFPC-W
Part Number290-914
UPC844632077401
Weight6
Nominal Diameter12"
Bolt Circle Diameter13
Power Handling (RMS)80 Watts
Power Handling (MAX)160 Watts
Frequency Response25 to 4,000Hz
Sensitivity90.5dB 2.83V/1m
Voice Coil Diameter1.5"
Resonant Frequency (Fs)31.2Hz
DC Resistance (Re)5.8Ω
Voice Coil Inductance (Le)0.71mH
Mechanical Q (Qms)3.41
Electromagnetic Q (Qes)0.89
Total Q (Qts)0.7
Compliance Equivalent Volume (Vas)5.45ft³
Mechanical Compliance of Suspension (Cms)0.457mm/N
BL Product (BL)8.6T·m
Diaphragm Mass Inc. Airload (Mms)57g
Maximum Linear Excursion (Xmax)4.3mm
Surface Area of Cone (Sd)487.9cm²
Cone MaterialPaper
Surround MaterialFoam
Overall Outside Diameter14.38"
Baffle Cutout Diameter11"
Depth4.5"
Sealed Volume3.5ft³
Sealed F341Hz
Vented Volume5ft³
Vented F330Hz
