  • GRS 10SFPC-W 10" Square Frame Paper Cone Woofer White
GRS
Part #290-910
GRS
Part #290-910
Model: 10SFPC-W
A perfect replacement woofer for classic hi-fi loudspeakers! The oversized decorative squared-off frame accommodates a wide variety of OEM driver cutouts.
  • Attractive square stamped steel frame
  • Smooth response and hefty bass output
  • Treated paper cone
  • Foam half roll edge
  • Choice of white or black cone
Your Price: $19.98
MSRP: $49.99
Save $30.01 (60%)
Quantity:Qty: 1-3 $19.98/ea
Quantity:Qty: 4+$17.98/ea
Order in the next 13 hr 48 min to ship today. Details
234In Stock
A perfect replacement woofer for classic hi-fi loudspeakers! The oversized decorative squared-off frame accommodates a wide variety of OEM driver cutouts. Smooth response and generous Xmax ensure optimum performance, and the use of modern materials and adhesives means your "experienced" speaker system will serve for many more years to come. Also great for DIY projects. Available in white or black cone versions.
BrandGRS
Model10SFPC-W
Part Number290-910
UPC844632077388
Weight4.6
Nominal Diameter10"
Power Handling (RMS)75 Watts
Power Handling (MAX)150 Watts
Frequency Response30 to 4,000Hz
Sensitivity88.9dB 2.83V/1m
Voice Coil Diameter1.5"
Resonant Frequency (Fs)34.1Hz
DC Resistance (Re)5.9Ω
Voice Coil Inductance (Le)0.68mH
Mechanical Q (Qms)2.92
Electromagnetic Q (Qes)0.9
Total Q (Qts)0.67
Compliance Equivalent Volume (Vas)2.92ft³
Maximum Linear Excursion (Xmax)4.3mm
Surface Area of Cone (Sd)353.9cm²
Cone MaterialPaper
Surround MaterialFoam
Overall Outside Diameter12, across the flats 10.75"
Baffle Cutout Diameter9.125"
Depth4"
Sealed Volume2.5ft³
Sealed F343Hz
Vented Volume3ft³
Vented F331Hz
MONSTER DEAL
OF THE WEEK
$98.98 EACH
SAVE 40%
Dayton Audio DTA-PRO 100W Class D Bluetooth Amplifier with USB DAC IR Remote and Sub Output
