  • GRS 12SFPC-B 12" Square Frame Paper Cone Woofer Black
GRS
Part #290-916
GRS
Part #290-916
Model: 12SFPC-B
A perfect replacement woofer for classic hi-fi loudspeakers! The oversized decorative squared-off frame accommodates a wide variety of OEM driver cutouts.
  • Attractive square stamped steel frame
  • Smooth response and hefty bass output
  • Treated paper cone
  • Foam half roll edge
Your Price: $24.98
MSRP: $69.99
Save $45.01 (64%)
Quantity:Qty: 1-3 $24.98/ea
Quantity:Qty: 4+$22.48/ea
Order in the next 2 hr 30 min to ship today. Details
A perfect replacement woofer for classic hi-fi loudspeakers! The oversized decorative squared-off frame accommodates a wide variety of OEM driver cutouts. Smooth response and generous Xmax ensure optimum performance, and the use of modern materials and adhesives means your "experienced" speaker system will serve for many more years to come. Also great for DIY projects.
BrandGRS
Model12SFPC-B
Part Number290-916
UPC844632077418
Weight6
Nominal Diameter12"
Bolt Circle Diameter13
Power Handling (RMS)80 Watts
Power Handling (MAX)160 Watts
Frequency Response35 to 3,000Hz
Sensitivity92dB 2.83V/1m
Voice Coil Diameter1.5"
Resonant Frequency (Fs)36Hz
DC Resistance (Re)5.9Ω
Voice Coil Inductance (Le)0.4mH
Mechanical Q (Qms)4.11
Electromagnetic Q (Qes)1.04
Total Q (Qts)0.83
Compliance Equivalent Volume (Vas)5.87ft³
Mechanical Compliance of Suspension (Cms)0.47mm/N
BL Product (BL)7.3T·m
Diaphragm Mass Inc. Airload (Mms)40.9g
Maximum Linear Excursion (Xmax)4.3mm
Surface Area of Cone (Sd)500cm²
Cone MaterialPaper
Surround MaterialFoam
Overall Outside Diameter14.375"
Baffle Cutout Diameter11"
Depth4.5"
Sealed Volume4ft³
Sealed F343Hz
Vented Volume5ft³
Vented F335Hz
MONSTER DEAL
OF THE WEEK
$98.98 EACH
SAVE 40%
Dayton Audio DTA-PRO 100W Class D Bluetooth Amplifier with USB DAC IR Remote and Sub Output
