  • Eminence LA-WG14 5.2" x 6.4" x 7.1" Line Array Waveguide
Eminence Speaker
Part #290-5504
Eminence Speaker
Part #290-5504
Model: LA-WG14
Eminence's LA-WG14 line array waveguide provide the wide horizontal and narrow vertical coverage need for large tightly packed professional line array systems. With a 1.4" throat and 4-bolt mount, the LA-WG14 is compatible with many popular high frequency drivers.
  • Rigid reinforced aluminum for low weight and reliable performance
  • Durable black powder coat finish resists corrosion
  • Acoustically loads compression drivers down to 1,000 Hz
  • Compact design allows tight spacing for minimal lobing
Your Price: $74.99
MSRP: $109.99
Save $35.00 (32%)
The Eminence LA-WG14 Line Array Waveguide offers wide horizontal high frequency coverage in tight fitting line array systems. Made from lightweight cast aluminum, the LA-WG14 is designed for 1.4" exit bolt-on compression drivers, and features a 140° x 15° degree dispersion. Pair with the Eminence N314T-8 or other 1.4" exit compression drivers for the ultimate in smooth, clean high frequency reproduction.
Specifications: • Horn type: Line array • Minimum frequency: 1,000 Hz • Nominal dispersion: 140° H x 15° V • Throat diameter: 1.4" • Mounting type: 4-bolt • Dimensions: 6.4" H x 5.2" W x 7.1" D • Cabinet cutout: 6" H x 1" W.
BrandEminence Speaker
ModelLA-WG14
Part Number290-5504
UPC876358003976
Weight2.6
ConstructionAluminum
Entry / Throat Diameter1.4"
Mounting Type4-Bolt
