  • Eminence LA-WG10 3.5" x 4.4" x 4.4" Line Array Waveguide
Eminence Speaker
Part #290-5502
Eminence Speaker
Part #290-5502
Model: LA-WG10
Eminence's LA-WG10 line array waveguide provide the wide horizontal and narrow vertical coverage need for large tightly packed professional line array systems. With a 1" throat and 2-bolt mount, the LA-WG10 is compatible with most popular high frequency drivers.
  • Rigid reinforced aluminum for low weight and reliable performance
  • Durable black powder coat finish resists corrosion
  • Acoustically loads compression drivers down to 1,800 Hz
  • Compact design allows tight spacing for minimal lobing
Your Price: $69.99
MSRP: $99.99
Save $30.00 (30%)
The Eminence LA-WG10 Line Array Waveguide offers wide horizontal high frequency coverage in tight fitting line array systems. Made from lightweight cast aluminum, the LA-WG10 is designed for 1" exit bolt-on compression drivers, and features a 140° x 15° degree dispersion. Pair with the Eminence N151M-8 or other 1" exit compression drivers for the ultimate in smooth, clean high frequency reproduction.
Specifications: • Horn type: Line array • Minimum frequency: 1,800 Hz • Nominal dispersion: 140° H x 15° V • Throat diameter: 1" • Mounting type: 2-bolt • Dimensions: 4.4" H x 3.5" W x 4.4" D • Cabinet cutout: 4" H x 1" W./p>
BrandEminence Speaker
ModelLA-WG10
Part Number290-5502
UPC876358004010
Weight1.2
ConstructionAluminum
Entry / Throat Diameter1"
Mounting Type2-Bolt
MONSTER DEAL
OF THE WEEK
$19.98 EACH
SAVE $10
