Eminence N314T-8 1.4" Neo Compression Driver 8 Ohm 4-Bolt
- Copper shorting ring lowers distortion and voice coil inductance
- Powerful neodymium magnet keeps weight and size to a minimum
- Cooling fins and 3" voice coil ensure high power handling for extended periods
- 550 Hz resonance frequency allows crossover points as low as 800 Hz
Only 3 In Stock
We'll send you an email when Eminence N314T-8 1.4" Neo Compression Driver 8 Ohm 4-Bolt is back in stock or available for preorder.
