  • Eminence Impero 15C 15" Professional Paper Cone Woofer 4 ohms
BUYOUT Eminence Impero 15C 15" Professional Paper Cone Woofer 4 ohms
Factory Buyouts
Part #299-2256
Factory Buyouts
Part #299-2256
Model: Impero 15C
Capable of handling up to 1,200 watts RMS, high excursion, and excellent low frequency output, the Eminence Impero-15C is an excellent driver for use in high output sound reinforcement sound systems. This 15” woofer features a 4” copper voice coil, rugged cast aluminum frame, and water resistant cone to ensure reliable high output bass response even in less than ideal environments.
  • 4” copper voice coil on a fiberglass former can handle up to 1,200 watts RMS (2,400 max)
  • Ample venting keeps power compression under control
  • Water resistant paper cone and dustcap makes this driver suitable for outdoor installations
  • Cast aluminum frame to handle the demanding sound reinforcement environment
  • Designed and assembled in the USA
BUYOUT $89.93
MSRP: $149.88
Save $59.95 (40%)
Order in the next 6 hr 30 min to ship today. Details
The Eminence Impero 15C 15" woofer was engineered to deliver high output bass response in challenging professional sound environments. A 4” voice coil, vented fiberglass former, and vented motor assembly allows this driver to handle up to 1,200 watt RMS (2,400 max) while keeping power compression to a minimum. Thanks to a flat spider and double roll cloth surround cone movement is kept linear even when pushed to the limits of it’s 14.8 mm peak to peak excursion. The cone, dustcap, and surround have all been treated with a water resistant coating making this perfect for use in sound systems that may be exposed to the elements.
Optimized for use in compact vented enclosures, the Impero-15C is an excellent choice for concert, arena, theater, dance club, or even portable sound reinforcement speaker systems.
Note: This new old stock driver is from a factory buyout. At such an economical price, these drivers won't last forever, quantities are limited.
BrandFactory Buyouts
ModelImpero 15C
Part Number299-2256
UPC848864077314
Weight20
Nominal Diameter15"
Bolt Circle Diameter14.56
Power Handling (RMS)1200 Watts
Power Handling (MAX)2400 Watts
Frequency Response50 to 2,000Hz
Sensitivity99.8dB 2.83V/1m
Voice Coil Diameter4"
Resonant Frequency (Fs)40.3Hz
DC Resistance (Re)3.1Ω
Voice Coil Inductance (Le)1.1mH
Mechanical Q (Qms)10.96
Electromagnetic Q (Qes)0.34
Total Q (Qts)0.33
Compliance Equivalent Volume (Vas)4.31ft³
Mechanical Compliance of Suspension (Cms)0.12mm/N
BL Product (BL)17.4T·m
Diaphragm Mass Inc. Airload (Mms)131g
Maximum Linear Excursion (Xmax)7.4mm
Surface Area of Cone (Sd)849.6cm²
Cone MaterialTreated Paper
Surround MaterialCloth
Voice Coil FormerFiberglass
Overall Outside Diameter15.22"
Baffle Cutout Diameter13.99"
Depth6.56"
Sealed Volume2ft³
Sealed F394Hz
Vented Volume3.5ft³
Vented F344Hz
