  • Neutrik NL4MPRXX speakON Connector 4 Pole Round Chassis Mount
Neutrik
Part #092-054
Neutrik
Part #092-054
Model: NL4MPRXX
Patent protected, reliable, cost effective, and extremely durable, Neutrik's speakON series of professional speaker and amplifier connectors offers the "quick lock" locking system and recently redesigned inserts for the cable ends.
  • Industry standard "quick-lock" speaker connector
  • 4-pole connection
  • Large, robust mounting flange
  • Black finish
Your Price: $3.23
MSRP: $4.99
Save $1.76 (35%)
Quantity:Qty: 1-99 $3.23/ea
Quantity:Qty: 100-249 $3.01/ea
Quantity:Qty: 250+$2.90/ea
843In Stock
Neutrik's speakON series of professional speaker and amplifier connectors are recognized as the industry standard. Patent protected, reliable, cost effective, and extremely durable the speakON system offers the "quick lock" locking system. speakON panel receptacles with solder terminations also allow you to use quick disconnect type terminals (0.187" x 0.020") for ease and reliability of assembly.
The contacts in this series are touch proof and designed to prevent damage from arcing if disconnected under load. Ensuring fail-safe conditions for both the equipment and the operator. speakON meets the prevailing safety standards of IEC65, IEC348, CE, CSA and are UL rated (file #E135070). Connector type: Chassis connector/panel receptacle, 4-pole, round flange style with air-tight seal. Mfg. #NL4MPR.
BrandNeutrik
ModelNL4MPRXX
Part Number092-054
Weight0.0594
Circuit4-Pole
GenderMale
