  • Eminence 6-1/2" Line Array Series Sealed Back Midrange Speaker 8 Ohm
BUYOUT Eminence 6-1/2" Line Array Series Sealed Back Midrange Speaker 8 Ohm
Factory Buyouts
Part #299-2255
Factory Buyouts
Part #299-2255
Model: LA6-CBMR
Delivering high efficiency and controlled response, this sealed back midrange driver is engineered for use in 3-way high output line arrays. This wide band midrange driver offers incredible output capability with low distortion, making it ideal for use in any high output 3-way design.
  • Truncated frame helps to minimize center to center distance for better off axis response in line arrays
  • 2-layer 1-1/2” copper voice coil on a vented former can handle up to 150 watts RMS
  • 500 to 5,400 Hz bandwidth is perfect for large 3-way systems
  • 97 dB sensitivity ensures high SPL levels even without high power
  • Designed and assembled in the USA
BUYOUT $59.88
Order in the next 4 hr 54 min to ship today. Details
Originally designed for high output 3-way line arrays, this midrange driver will provide incredible performance in any larger 3-way system. The closed back frame means that this midrange does not require its own enclosure, making it easy to integrate into your next design. With a truncated frame the center-to-center distance between drivers can be kept to a minimum, helping to keep off-axis response under control when used in line arrays. A 1-1/2” voice coil wound on a vented polyimide former ensure high power handling, and with 97.8 dB sensitivity, this driver is capable of remarkable SPL levels. Weather you are designing a high output home, car, or professional sound system, this midrange will fit right in.
Designed and assembled in the USA.
Note: This new old stock driver is from a factory buyout. At such an economical price, these drivers won't last forever, quantities are limited.
BrandFactory Buyouts
ModelLA6-CBMR
Part Number299-2255
UPC848864077307
Weight6.95
Nominal Diameter6-1/2"
Bolt Circle Diameter6.25
Power Handling (RMS)150 Watts
Power Handling (MAX)300 Watts
Frequency Response500 to 5,400Hz
Sensitivity97.8dB 2.83V/1m
Voice Coil Diameter1.5"
Resonant Frequency (Fs)460Hz
DC Resistance (Re)6.3Ω
Voice Coil Inductance (Le)0.33mH
Mechanical Q (Qms)3.13
Electromagnetic Q (Qes)1.24
Total Q (Qts)0.89
Compliance Equivalent Volume (Vas)0.01ft³
Mechanical Compliance of Suspension (Cms)0.01mm/N
BL Product (BL)11.1T·m
Diaphragm Mass Inc. Airload (Mms)9g
Maximum Linear Excursion (Xmax)0.2mm
Cone MaterialPaper
Surround MaterialCloth
Overall Outside Diameter6.59"
Baffle Cutout Diameter5.65"
Depth2.77"
