  • Celestion CDX1-1446 1" High Frequency Compression Driver 8 Ohm
BUYOUT Celestion CDX1-1446 1" High Frequency Compression Driver 8 Ohm
Read 1 Review or
Factory Buyouts
Part #299-2257
Factory Buyouts
Part #299-2257
Model: T5796A(CDX1-1446)
Read 1 Review or
Celestion's CDX1-1446 1" 8 ohm compression driver features a compact design with state of the art technology. The one-piece PETP diaphragm provides reliable and natural response needed for professional sound systems, but low enough distortion for home designs as well.
  • 1" exit with 1-3/8"-18 TPI mount for easy installation
  • Durable design with a one piece PETP diaphragm and surround
  • Recommended 2,200 Hz 12 dB/octave crossover makes this driver suitable for both 2 way and 3 way designs
  • 106 dB sensitivity and 20 watt power handling ensures high output
  • Finite Element Analysis (FEA) techniques used to optimize both magnetic and acoustic components
BUYOUT $29.88
Order in the next 19 hr 43 min to ship today. Details
Celestion's compact and versatile CDX1-1446 1" high frequency driver with 1-3/8"-18 TPI mount is the result of the company's extensive experience, and its commitment to rigorous technical analysis. The driver's advanced non-metallic PETP diaphragm provides accurate, non-fatiguing response, while offering a higher level of durability than shatter-prone metallic domes. Thanks to the extended high frequency response and low distortion, the CDX1-1446 is a great choice as a tweeter in 2-way studio monitors and high output home speakers.
Note: This new old stock driver is from a factory buyout. At such an economical price, these drivers won't last forever, quantities are limited.
Specifications:• Power handling: 20 watts RMS with recommended crossover of 2,200 Hz, 12 dB/octave slope • VCdia: 1.4" • Impedance: 8 ohms • Frequency response: 1,500-20,000 Hz • SPL: 106 dB 1W/1m • Dimensions: 3.54" diameter x 2.71" depth • Net weight: 2.4 lbs. • Mounting: 1-3/8"-18 TPI
BrandFactory Buyouts
ModelT5796A(CDX1-1446)
Part Number299-2257
UPC848864077321
Weight2.5
Diaphragm MaterialPoly / Mylar
Exit Diameter1"
Mounting Type1-3/8"-18 TPI
Power Handling (RMS)20 Watts
