  • Dayton Audio XO2W-4.5K 2-Way Speaker Crossover 4,500 Hz
Dayton AudioPart # 260-148
Model: XO2W-4.5K
The Dayton Audio line of 2-way crossovers were designed using a second order (12 dB/octave) Linkwitz-Riley alignment. Dayton Audio metallized polyester film capacitors are used in both the high and low-pass sections.
  • 18 gauge inductors were used to keep DC resistance to a minimum
  • Unique design feature of the low pass section allows use of 4 or 8 ohm woofers
  • All components are glued or fastened down to eliminate buzzing and vibrations
  • High quality blue PC board uses a back plate for added rigidity
Your Price: $30.59
MSRP: $40.99
Save $10.40 (25%)
Quantity:Qty: 1-9 $30.59/ea
Quantity:Qty: 10+ $27.69/ea
24 In Stock
We'll send you an email when Dayton Audio XO2W-4.5K 2-Way Speaker Crossover 4,500 Hz is back in stock or available for preorder.
The Dayton Audio line of 2-way crossovers were designed using a second order (12 dB/octave) Linkwitz-Riley alignment. Dayton Audio metallized polyester film capacitors are used in both the high and low pass sections. 18 gauge inductors were used to keep DC resistance to a minimum. A unique design feature of the low-pass section allows for use of 4 or 8 ohm subwoofers, perfect for building D'Appolito style or multi woofer 2-way systems. The high-pass crossover frequency is rated for an 8 ohm load. All components are glued or fastened down to eliminate buzzing and vibrations. The high quality blue PC board uses a back plate for added rigidity and eyelet holes for easy mounting. Available in a variety of crossover points. 300W power handling. Board measures: 6-1/2" W x 4-1/4" H x 1-3/8" D. Terminals are 0.205".
ModelXO2W-4.5K
Part Number260-148
UPC844632045172
Weight1
Crossover Type2-Way
