  • Dayton Audio WP65WT 6-1/2" IP55 Indoor/Outdoor Landscape Speaker Pair 8 Ohm White
Dayton Audio
Part #310-021
Dayton Audio
Part #310-021
Model: WP65WT
The rugged Dayton Audio WP65WT speaker fits as well indoors as outdoors. Designed to deliver high-quality audio, the all-purpose speaker is perfect for both commercial and residential applications. Constructed from IP55 weather resistant ABS plastic, the WP65WT is perfect for outdoor patio use. With a 6.5" mineral-filled polypropylene woofer and a 1" fabric tweeter, the speaker delivers great sounding audio while providing versatile mounting options.
  • 6.5" woofer with a coaxial 7/8" tweeter providing a balanced, natural response
  • Versatile mounting brackets for pendant mounting, wall mount, or landscape applications
  • Integrated 70V transformer with selectable taps and 8 ohm bypass
  • Suitable for indoor and outdoor installation
  • Package includes 2 speakers, 2 wall mount end caps, 2 pendant mount end caps, 2 ball joint wall mounts, 2 landscape stakes, 2 eye bolts, all associated hardware
Your Price: $209.98
MSRP: $319.99
Save $110.01 (34%)
Order in the next 6 hr 39 min to ship today. Details
Dayton Audio WP65WT 6-1/2" IP66 Indoor/Outdoor Landscape Speaker
The Dayton Audio WP65WT indoor/outdoor multi-purpose speaker features a 2-way coaxial design complete with a 6.5" woofer and 1" tweeter. The IP66 weather resistant ABS plastic construction is able to withstand outdoor environments while remaining aesthetically pleasing for indoor use.
Key Specs:
  • Design:  Multi-Mount Pendant Speaker
  • Woofer: 6-1/2" Mineral-Filled Polypropylene Cone
  • Tweeter: 1" Fabric
  • Power Handling (RMS): 40 Watts @ 8 Ohms
  • Power Handling (MAX): 80 Watts  @8 Ohms
  • Frequency Response: 60-20,000 Hz
  • Full Specifications   Manual
We Got Your Back
Learn More
Versatile for Commercial and Residential Installs
The WP65WT can be used for both commercial and residential applications. The speaker features an integrated 70/100V transformer with multiple taps. The speaker also has an 8 ohm bypass for use with regular amplifiers. High quality audio comes standard with the WP65WT, even at 6.5" the woofer is able to provide an extended low end. No matter what your next job is, the WP65WT is a great choice for excellent sound in a discrete, compact enclosure.
Multiple Mounting Configurations
The WP65WT comes complete with mounting brackets for pendant, wall, and landscape mounting. The multiple mount configurations along with 70V and 8 ohm option provides the ultimate flexibility in application and installation design
Pendant Mount
Wall Mount
Landscape Mount
Pendant Mount
Mounting hardware includes a separate specialized end cap covering the transformer tap selection and phoenix wire connector with an eye bolt for connecting to a hanging device such as a steel safety cable.
Wall Mount
Mounting hardware includes a fully enclosed end cap protecting the transformer tap selection and phoenix wire connector. The speaker connects to a ball joint mount for both vertical and horizontal axis configuration.
Landscape Mount
Mounting hardware includes a fully enclosed end cap protecting the transformer tap selection and phoenix wire connector. The speaker connects to a ball joint mount which is attached to a landscape style stake providing sturdy support for the speaker
For Use Indoors & Out
If you need more mounting versatility, the Dayton Audio pendant indoor/outdoor speaker line provides multiple installation configurations including pendant mount, wall mount, and landscape mount. Complete with 70V/100V and 8‑ohm operation, the pendants can be used with commercial and consumer amps. Constructed from weather resistant ABS plastic, the pendant line stands up to any environment.
Uses:
  • Gardens, patios, landscaped audio
  • Pools, theme parks, attraction venues
  • Entertainment venues, bars, restaurants
  • Warehouses, shipping centers
Shop the Whole Pendant Line
WP4BT 4"
WP65BT 6-1/2"
WP65WT 6-1/2"
  • Size: 4"
  • Color: Black
  • Sold As: Pairs
  • Size: 6-1/2"
  • Color: Black
  • Sold As: Pairs
  • Size: 6-1/2"
  • Color: White
  • Sold As: Pairs
WP8BT 8"
WP8WT 8"
  • Size: 8"
  • Color: Black
  • Sold As: Single
  • Size: 8"
  • Color: White
  • Sold As: Single
Shop All Indoor/Outdoor Speakers
IO Line
  • 70V/100V transformer with 8‑ohm bypass
  • Weather resistant ABS plastic enclosure and aluminum grills provide years of service
  • Available in 5‑1/4", 6‑1/2", and 8" versions in black and white
IOX Line
  • Passive radiator produces extended low‑end response for deep, tight bass uncharacteristic of outdoor speakers
  • IP55 ABS enclosure protects the speaker from the outdoor elements
  • Available in 6‑1/2" and 8" versions in black and white
Pendant Line
  • Integrated 70V transformer with selectable taps and 8‑ohm bypass
  • Available in 4", 6‑1/2", and 8" versions in black and white (4" only available in black)
    Outdoor Subs
    Add additional low-end with Dayton Audio’s indoor/outdoor subwoofers. With a burial and above-ground versions, the subs make adding bass extremely easy to any patio, pool, gardens, or landscaped audio. Both versions are compact and discrete to not disrupt your area’s aesthetics. Rugged and weather resistant design ensure a long-lasting life. The sub line delivers outstanding bass and value for any outdoor audio system
    Shop Now
    Excellent Value, Great Sound
    "Overall, I was very impressed with the build quality and sound these produce. Every conceivable mounting option is provided. Flexible integration into 70V or, as I used them, standard 8ohm stereo pair. I did take the time to silicone the back plate just to make sure water didn't seep into the back side where the screw terminals are located. Not sure if it could but I didn't want to take any chances. For half the money of comparable Polk or Klipsch, I'd say these are a no brainer."
    - Matthew O.
    • Design: Indoor Outdoor Multi-Mount Pendants
    • Impedance: 8Ω / 70V / 100V
    • 70V Taps: NC, 20, 10, 5, 2.5W
    • 100V Taps: NC, 40, 20, 10, 5W
    • SPL: 87 dB / 88 dB @ 8 Ohms setting 2.83V/1m
    • Ingress Protection Rating: IP55
    • Landscape Stake Length: 3-1/2" Dia. x 8-1/4" L
    • Wall Mount Dimensions: 3-1/2" Dia. x 4-1/2" L (4 screw holes)
    • Pendant Mount Support Dimensions: 8" Dia. (8 screw holes)
    • Dimensions: 10-1/4" H x 8-1/8" Dia.
    • Weight: 10 lbs. (each)
    Need Some More Help?
    Need some help with your project? Part Express's technical support staff can help answer any questions that you might have and help ensure that your speaker design and build are successful.
    Customer Service
    To enquire about an order or report an order problem:
    Email: CustomerService@Parts-Express.com
    Phone: 1-800-338-0531
    Hours: 8 AM–6 PM Monday – Friday ET
    Closed Saturday & Sunday
    Technical Support
    To get technical information about our products:
    Email: Tech@Parts-Express.com
    Hours 8 AM-6 PM Monday - Friday ET
    Additional Resources
    Get Inspired and Learn From The Best
    Parts Express is a leading supplier in raw drivers, speaker components, and resources for speaker builders. Whether you are a seasoned vet or someone looking to find a new hobby, Parts Express has the gear and resources you need to complete your next project. The large community of speaker builders on our Tech Talk forum allow you to learn from some of the best in the business. For more inspiration, check out the Project Gallery which showcases a variety of designs from the speaker building community.
    ModelWP65WT
    Part Number310-021
    UPC848791005985
    Unit of MeasurePairs
    Weight20.45
    ColorWhite
    ConfigurationCoaxial
    Input Rating8 ohm|70V|100V
    Mounting StyleLandscape
    Woofer Diameter6.5"
    Special FeaturesWeather Resistant
