  • Dayton Audio RSS265HO-44 10" Reference Series HO DVC Subwoofer
Dayton AudioPart # 295-463
Model: RSS265HO-44
The RSS265HO-44 10" High Output Reference Subwoofer from Dayton Audio is designed for high power handling and extremely low distortion. A small enclosure requirement allows it to be used in car audio and space limited home audio applications.
  • Dual 4 ohm voice coils for many wiring options
  • Extensively vented motor eliminates compression and allows quiet excursion
  • Extra-thick black anodized aluminum cone for maximum rigidity
  • Triple shorting-ring motor for ultra-low distortion
  • Parameters optimized for small enclosures
  • Highest quality materials throughout for long-lasting performance
Your Price: $239.98
MSRP: $311.99
Save $72.01 (23%)
Quantity:Qty: 1-3 $239.98/ea
Quantity:Qty: 4+ $232.91/ea
We'll send you an email when Dayton Audio RSS265HO-44 10" Reference Series HO DVC Subwoofer is back in stock or available for preorder.
Order in the next 5 hr 4 min to ship today. Details
Dayton Audio's 10" RSS265HO-44 High Output Reference Series subwoofer is purpose-built for moving lots of air, extreme power handling, extremely low distortion... and it does it all with an extremely small enclosure requirement! The minimum airspace optimization of this driver makes it perfect for car audio automotive applications and limited space home audio applications.
To minimize distortion, three copper short-circuit paths are built into the motor. This reduces second, third, and intermodulation distortion to levels only attained previously by expensive, exotic subwoofers. A side benefit is reduced energy storage and inductance, making the RSS265-HO-44 a very musical subwoofer. In fact, frequency response remains very flat up to 500 Hz.
Additional features include: a heavy gauge black anodized aluminum cone that resists deformation from extreme air pressure levels found inside of small sealed enclosures, a fully ventilated motor for reduced power compression, a rigid cast aluminum frame for structural integrity, and a tough rubber surround that won't wear down over years of use. Dual 4-ohm voice coils allow for a wide array of wiring options.
As with all Dayton Audio subwoofers, you receive a full 5-year warranty. Designed and engineered in the U.S.A.
Note: This is a dual voice coil driver, 4 ohms per coil. Specifications below were measured with the voice coils wired in parallel for a 2 ohm load.
ModelRSS265HO-44
Part Number295-463
UPC848791000324
Weight17.2
Nominal Diameter10"
Bolt Circle Diameter9.75
Power Handling (RMS)600 Watts
Frequency Response25 to 600Hz
Sensitivity90.5dB 2.83V/1m
Voice Coil Diameter2.58"
Resonant Frequency (Fs)27.6Hz
DC Resistance (Re)1.6Ω
Voice Coil Inductance (Le)0.77mH
Mechanical Q (Qms)4.42
Electromagnetic Q (Qes)0.5
Total Q (Qts)0.45
Compliance Equivalent Volume (Vas)1.23ft³
Mechanical Compliance of Suspension (Cms)0.21mm/N
BL Product (BL)9.39T·m
Diaphragm Mass Inc. Airload (Mms)161g
Maximum Linear Excursion (Xmax)13.25mm
Surface Area of Cone (Sd)352.3cm²
Cone MaterialAluminum
Overall Outside Diameter10.5"
Baffle Cutout Diameter9.25"
Depth5"
# Mounting Holes6
Sealed Volume0.6ft³
Sealed F349Hz
Vented Volume1.5ft³
Vented F325Hz
