  • Dayton Audio RSS210HF-4 8" Reference Series HF Subwoofer 4 Ohm
Dayton Audio
Part #295-456
Dayton Audio
Part #295-456
Model: RSS210HF-4
The Dayton Audio Reference Series subwoofers take the quality and performance of the much acclaimed RS line into the subwoofer realm. The black anodized cone, rubber surround, and custom basket give this driver a unique, high-end look.
  • Extensively vented motor eliminates compression and allows quiet excursion
  • Lightweight black anodized aluminum cone for rigidity and lower moving mass
  • Suitable for sealed or vented enclosures
  • Triple shorting ring motor for ultra-low distortion
  • 2-layer coil for reduced back EMF
  • Highest quality materials throughout for long-lasting performance
Your Price: $129.98
MSRP: $175.99
Save $46.01 (26%)
Quantity:Qty: 1-3 $129.98/ea
Quantity:Qty: 4+$125.98/ea
Order in the next 5 hr 13 min to ship today. Details
The Dayton Audio Reference Series subwoofers take the quality and performance of the much acclaimed RS line into the subwoofer realm. As with the rest of the Reference Series, the main focus of these subwoofers is ultra-low-distortion. Second, third, and intemodulation distortion are kept extremely low by utilizing three short-circuit paths within the motor structure. A durable aramid fiber spider and extensive venting throughout provide quiet and uniform excursion. The black anodized cone, rubber surround, and custom basket give this driver a unique, high-end look. Choose the high fidelity version for home systems when you are looking for clean, low bass and are not restricted by cabinet size.
ModelRSS210HF-4
Part Number295-456
UPC844632062308
Weight8.8
Nominal Diameter8"
Power Handling (RMS)280 Watts
Power Handling (MAX)560 Watts
Frequency Response27 to 1,000Hz
Sensitivity85.6dB 2.83V/1m
Voice Coil Diameter2"
Resonant Frequency (Fs)29.6Hz
DC Resistance (Re)3.1Ω
Voice Coil Inductance (Le)0.7mH
Mechanical Q (Qms)3.25
Electromagnetic Q (Qes)0.69
Total Q (Qts)0.57
Compliance Equivalent Volume (Vas)0.84ft³
Mechanical Compliance of Suspension (Cms)0.37mm/N
BL Product (BL)8.12T·m
Diaphragm Mass Inc. Airload (Mms)78.4g
Maximum Linear Excursion (Xmax)9mm
Surface Area of Cone (Sd)219cm²
Cone MaterialAluminum
Voice Coil FormerAluminum
Overall Outside Diameter8.39"
Baffle Cutout Diameter7.28"
Depth4.88"
# Mounting Holes6
Sealed Volume0.9ft³
Sealed F341Hz
Vented Volume1.25ft³
Vented F323Hz
