  • Dayton Audio RSS210HO-8 8" Reference Series HO Subwoofer 8 ohm
Dayton Audio
Part #295-459
Dayton Audio
Part #295-459
Model: RSS210HO-8
The Dayton Audio Reference Series subwoofers take the quality and performance of the much acclaimed RS line into the subwoofer realm. The black anodized cone, rubber surround, and custom basket give this driver a unique, high-end look.
  • Extensively vented motor eliminates power compression and allows quiet excursion
  • Triple shorting-ring motor for ultra-low distortion
  • Heavy-gauge aluminum cones withstand pressures of small enclosures
  • 4-layer high-temperature coils for maximum power handling
  • Durable aramid fiber spider for greater mechanical control
  • Unique, high-end look
  • Optimized for small enclosures
Your Price: $139.98
MSRP: $194.99
Save $55.01 (28%)
Quantity:Qty: 1-3 $139.98/ea
Quantity:Qty: 4+$134.98/ea
Order in the next 4 hr 37 min to ship today. Details
The Dayton Audio Reference Series subwoofers take the quality and performance of the much acclaimed RS line into the subwoofer realm. As with the rest of the Reference Series, the main focus of these subwoofers is ultra-low-distortion. Second, third, and intemodulation distortion are kept extremely low by utilizing three short-circuit paths within the motor structure. A durable aramid fiber spider and extensive venting throughout provide quiet and uniform excursion. The black anodized cone, rubber surround, and custom basket give this driver a unique, high-end look.
ModelRSS210HO-8
Part Number295-459
UPC848791000348
Weight11.7
Nominal Diameter8"
Power Handling (RMS)300 Watts
Power Handling (MAX)500 Watts
Frequency Response30 to 1,500Hz
Sensitivity83.5dB 2.83V/1m
Voice Coil Diameter2"
Resonant Frequency (Fs)29.6Hz
DC Resistance (Re)5.9Ω
Voice Coil Inductance (Le)1.46mH
Mechanical Q (Qms)2.78
Electromagnetic Q (Qes)0.45
Total Q (Qts)0.39
Compliance Equivalent Volume (Vas)0.66ft³
Mechanical Compliance of Suspension (Cms)0.29mm/N
BL Product (BL)15.6T·m
Diaphragm Mass Inc. Airload (Mms)99.3g
Maximum Linear Excursion (Xmax)12mm
Surface Area of Cone (Sd)213.8cm²
Cone MaterialAluminum
Overall Outside Diameter8.39"
Baffle Cutout Diameter7.28"
Depth4.96"
Sealed Volume0.3ft³
Sealed F360Hz
Vented Volume0.8ft³
Vented F328Hz
