  • Dayton Audio RS180-8 7" Reference Woofer
Dayton Audio
Part #295-355
Dayton Audio
Part #295-355
Model: RS180-8
Dayton Audio Reference Series RS180-8 7" woofers deliver exceptional clarity, detail, and dynamics--and of course, incredibly low distortion.
  • One of the lowest distortion, highest resolution driver series available
  • Low-distortion high-excursion motor system with two short-circuit paths
  • Compliant suspension and rigid black anodized aluminum cone for strong bass performance
  • Heavy-duty 6-hole cast frame, low-loss rubber surround, and solid aluminum phase plug
  • Designed and engineered in the USA
Your Price: $69.98
MSRP: $81.99
Save $12.01 (15%)
Quantity:Qty: 1-3 $69.98/ea
Quantity:Qty: 4+$62.98/ea
Order in the next 4 hr 39 min to ship today. Details
The Dayton Audio Reference Series was conceived with one goal in mind—low distortion. Each speaker was carefully designed and optimized to offer the highest performance with the lowest distortion levels. At the same time, by focusing on features that contribute to sound quality and eliminating unnecessary frills, the drivers offer value unparalleled in the industry. Dayton Audio Reference Series RS180-8 7" woofers deliver exceptional clarity, detail, and dynamics—and of course, incredibly low distortion.
ModelRS180-8
Part Number295-355
UPC844632088759
Weight4.85
Nominal Diameter7"
Bolt Circle Diameter6.63
Power Handling (RMS)60 Watts
Power Handling (MAX)120 Watts
Frequency Response39 to 3,600Hz
Sensitivity87.1dB 2.83V/1m
Voice Coil Diameter1.5"
Resonant Frequency (Fs)35.7Hz
DC Resistance (Re)6.4Ω
Voice Coil Inductance (Le)0.73mH
Mechanical Q (Qms)1.22
Electromagnetic Q (Qes)0.42
Total Q (Qts)0.31
Compliance Equivalent Volume (Vas)0.86ft³
Mechanical Compliance of Suspension (Cms)1.12mm/N
BL Product (BL)7.82T·m
Diaphragm Mass Inc. Airload (Mms)17.9g
Surface Area of Cone (Sd)124.7cm²
Cone MaterialAluminum
Voice Coil FormerAluminum
Overall Outside Diameter7.11"
Baffle Cutout Diameter5.75"
Depth3.19"
# Mounting Holes6
Sealed Volume0.25ft³
Sealed F3108Hz
Vented Volume0.45ft³
Vented F348Hz
