  • Dayton Audio RS180-4 7" Reference Woofer 4 Ohm
Dayton Audio
Part #295-374
Dayton Audio
Part #295-374
Model: RS180-4
The Dayton Audio Reference Series sets a new standard of value in high-performance loudspeaker drivers. Woofer features a black anodized cone, heavy-duty 6-hole cast frame, low-loss rubber surround, solid aluminum phase plug, and gold spring terminals.
  • 4 ohm impedance is perfect for series pairs in MTMs and center channel speakers
  • Excellent car audio midrange/midbass
  • High-end low-distortion motor with two shorting paths to reduce inductance
Your Price: $69.98
MSRP: $84.99
Save $15.01 (18%)
Quantity:Qty: 1-3 $69.98/ea
Quantity:Qty: 4+$62.98/ea
Order in the next 6 hr 2 min to ship today. Details
The Dayton Audio Reference Series sets a new standard of value in high-performance loudspeaker drivers. Utilizing a low-distortion motor system with two short-circuit paths and a rigid aluminum cone, the Reference Series can outperform drivers that cost several times the price. Their low-distortion characteristics and high excursion capabilities provide exceptional clarity, detail, and dynamics. Woofer features a black anodized cone, heavy-duty 6-hole cast frame, low-loss rubber surround, solid aluminum phase plug, and gold spring terminals.
ModelRS180-4
Part Number295-374
UPC844632054242
Weight5.1
Nominal Diameter7"
Bolt Circle Diameter6.63
Power Handling (RMS)60 Watts
Power Handling (MAX)120 Watts
Frequency Response39 to 3,600Hz
Sensitivity89.2dB 2.83V/1m
Voice Coil Diameter1.5"
Resonant Frequency (Fs)38.4Hz
DC Resistance (Re)3.1Ω
Voice Coil Inductance (Le)0.45mH
Mechanical Q (Qms)2.13
Electromagnetic Q (Qes)0.59
Total Q (Qts)0.46
Compliance Equivalent Volume (Vas)0.75ft³
Mechanical Compliance of Suspension (Cms)0.97mm/N
BL Product (BL)4.71T·m
Diaphragm Mass Inc. Airload (Mms)17.8g
Surface Area of Cone (Sd)124.7cm²
Cone MaterialAluminum
Voice Coil FormerAluminum
Overall Outside Diameter7.11"
Baffle Cutout Diameter5.75"
Depth3.23"
# Mounting Holes6
Sealed Volume0.22ft³
Sealed F378Hz
Vented Volume0.67ft³
Vented F339Hz
MONSTER DEAL
OF THE WEEK
$14.98 EACH
SAVE 25%
Dayton Audio Boost Mini Portable Bluetooth Speaker Black
