  • Dayton Audio PA200-8 8" Pro Woofer Speaker 8 Ohm
Dayton Audio
Part #295-025
Dayton Audio
Part #295-025
Dayton Audio's PA200-8 PA Series 8" professional woofer is a great upgrade for musical instrument or sound reinforcement cabinets, and also excels in custom-built speaker systems.
  • Strong, low-mass carbon fiber impregnated paper cone
  • Low distortion motor system with copper cap
  • Vented pole piece and voice coil gap improve thermal management
  • Black motor parts and black polyimide voice coil former dissipate heat
  • Bumped back plate for unrestricted excursion
Your Price: $54.98
MSRP: $97.99
Save $43.01 (44%)
Quantity:Qty: 1-3 $54.98/ea
Quantity:Qty: 4+$48.49/ea
Only 16 In Stock
More due any day
The PA200-8 8" professional audio woofer, from Dayton Audio, features high power handling by using a vented pole piece and voice coil gap. Black motor parts (including a black polyimide voice coil) help dissipate heat away from the voice coil and help to minimize power compression.
Extended, smooth frequency response and low distortion are achieved through the use of a powerful 50 ounce ceramic ferrite magnet, combined with a copper cap on the pole piece to reduce stray eddy currents and minimize voice coil inductance.
A strong, low-mass, carbon fiber-impregnated paper cone, together with an I-beam rolled-edge 1.2 mm steel frame provides the rugged durability needed to handle the rigors of touring and for stage use, while still offering the sensitivity and punchy bass that you need.
Dayton Audio's PA Series woofer packs all of these premium features into a value-priced 8" driver that is great for use as an upgrade to sound reinforcement or musical instrument speakers. The PA200-8 also excels in custom-built speakers.
ModelPA200-8
Part Number295-025
UPC848791000546
Weight7.25
Nominal Diameter8"
Bolt Circle Diameter7.95
Power Handling (RMS)250 Watts
Power Handling (MAX)500 Watts
Frequency Response70 to 9,000Hz
Sensitivity92.4dB 2.83V/1m
Voice Coil Diameter2"
Resonant Frequency (Fs)55.2Hz
DC Resistance (Re)6.2Ω
Voice Coil Inductance (Le)1.09mH
Mechanical Q (Qms)6.17
Electromagnetic Q (Qes)0.51
Total Q (Qts)0.48
Compliance Equivalent Volume (Vas)1ft³
Mechanical Compliance of Suspension (Cms)0.4mm/N
BL Product (BL)9.28T·m
Diaphragm Mass Inc. Airload (Mms)20.5g
Surface Area of Cone (Sd)210.4cm²
Cone MaterialPaper / Kevlar
Surround MaterialCloth
Overall Outside Diameter8.27"
Baffle Cutout Diameter7.17"
Depth3.82"
Sealed Volume0.35ft³
Sealed F3100Hz
Vented Volume0.75ft³
Vented F361Hz
